- To:
- Subject: Re: [cgal-discuss] Strange output from Delaunay triangulation
- Date: Fri, 25 Sep 2009 19:15:29 +0200
Sybren A. Stüvel wrote:
Hi folks,
I'm building a Delaunay triangulation in 3D. After I added 29 points
and stream the triangulation to a file I get the attached output. It
contains the 29 points and 129 cells.
The first cell consists of vertices "15 0 5 19", so I assume vertex
indices are 0 based. However, another cell consists of vertices "13 7
29 19". How can this be when there are only 29 points?
Can anyone shed some light on this? I've attached a rather minimal
test program and its output. I compiled it on Ubuntu Linux using:
g++ -fno-gnu-keywords -pedantic -Wall -Weffc++ -Wextra -std=c++98 -g
-lCGAL basetest.cpp -o basetest
but I saw the same problem on Windows XP with Visual C++ 2005 SP1.
I use CGAL 3.4.
Cheers,
Hi Sybren,
There is the infinite vertex with index 0. So the cells with an index 0
are the cells outside of the convex hull.
andreas
- [cgal-discuss] Strange output from Delaunay triangulation, Sybren A . Stüvel, 09/25/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Andreas Fabri, 09/25/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Sybren A . Stüvel, 09/25/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Laurent Rineau (GeometryFactory), 09/25/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Laurent Rineau (GeometryFactory), 09/26/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Sybren A . Stüvel, 09/27/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Laurent Rineau (GeometryFactory), 09/27/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Monique Teillaud, 09/28/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Sybren A . Stüvel, 09/28/2009
