- To:
- Subject: Re: [cgal-discuss] Strange output from Delaunay triangulation
- Date: Fri, 25 Sep 2009 19:20:14 +0200
Le vendredi 25 septembre 2009 19:05:47, Sybren A. Stüvel a écrit :
> Hi folks,
> I'm building a Delaunay triangulation in 3D. After I added 29 points
> and stream the triangulation to a file I get the attached output. It
> contains the 29 points and 129 cells.
> The first cell consists of vertices "15 0 5 19", so I assume vertex
> indices are 0 based. However, another cell consists of vertices "13 7
> 29 19". How can this be when there are only 29 points?
> Can anyone shed some light on this? I've attached a rather minimal
> test program and its output. I compiled it on Ubuntu Linux using:
> g++ -fno-gnu-keywords -pedantic -Wall -Weffc++ -Wextra -std=c++98 -g
> -lCGAL basetest.cpp -o basetest
> but I saw the same problem on Windows XP with Visual C++ 2005 SP1.
> I use CGAL 3.4.
Hi,
That is very nice that you attached your code. I have been repeating on this
list how much that is important to get useful answers.
The file output of CGAL triangulation is not documented. It is not intended
to
be used by users. However, that is not really a secret either: the source
code
is published. The file output stores in the file all cells of the
triangulation,
even the infinite cells. The vertex #0 is probably the infinite vertex. If
you
only want the finite cells of the triangulation (that is, those that are
inside
the convex hull of the points), then just ignore the cells that have the
vertex #0.
You can find an explanation about the infinite vertex and infinite cells in
the
manual, at the very beginning of the chapter about 3D triangulations:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3/Chapter_main.html
Laurent Rineau, PhD
Release Manager of the CGAL Project
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] Strange output from Delaunay triangulation, Sybren A . Stüvel, 09/25/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Andreas Fabri, 09/25/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Sybren A . Stüvel, 09/25/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Laurent Rineau (GeometryFactory), 09/25/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Laurent Rineau (GeometryFactory), 09/26/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Sybren A . Stüvel, 09/27/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Laurent Rineau (GeometryFactory), 09/27/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Monique Teillaud, 09/28/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Sybren A . Stüvel, 09/28/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Bernd Gaertner, 09/28/2009
- Re: [cgal-discuss] Strange output from Delaunay triangulation, Laurent Rineau (GeometryFactory), 09/28/2009
