- To:
- Subject: Re: [cgal-discuss] vertex methods problem
- Date: Sat, 26 Sep 2009 16:17:45 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=wH1ZNH6P4XeiqEf4z9eYv2aza5/hDQjmxx5P1zES8ldAIiM/JAWOhz6U03ggDVEt6C rTmO32gC9wEVW30y4Gy9dAM6hddVOMa/GZGojTzaDGT2wf3taxPeV0RBGehrRJvbYgQQ szYjArISP3d7dQOuWsLVL8NuVKie6z8CkUBUY=
e.vertex()->... it's the right thing I should have posted.
Best regards.
2009/9/26 <>
Quoting Sterpa <>:
I'm trying to do this
if(!e.vertex().boundary_in_x()) { ... }
The method is called parameter_space_in_x (). Besides, it's a bit surprising that you are using the "." operator and not the '->' operator.
and I get this error:
/usr/local/include/CGAL/Arrangement_on_surface_2.h: In function ‘int
getLevel(Halfedge, std::vector<CGAL::Line_2<CGAL::Simple_cartesian<double> >,
std::allocator<CGAL::Line_2<CGAL::Simple_cartesian<double> > > >)’:
/usr/local/include/CGAL/Arrangement_on_surface_2.h:736: error: ‘typename
TopTraits_::Dcel::Vertex* CGAL::Arrangement_on_surface_2<GeomTraits_,
TopTraits_>::Halfedge::vertex() [with GeomTraits_ =
CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double> >, TopTraits_ =
CGAL::Arr_unb_planar_topology_traits_2<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
,CGAL::Arr_default_dcel<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
> >]’ is privatearrangement.cpp:214: error: within this context
arrangement.cpp:214: error: request for member ‘boundary_in_x’ in
‘e.CGAL::Arrangement_on_surface_2<GeomTraits_, TopTraits_>::Halfedge::vertex
[with GeomTraits_ = CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double> >,
TopTraits_ =
> >]()’, which is of non-class type‘CGAL::Arr_vertex<CGAL::Arr_vertex_base<CGAL::Point_2<CGAL::Simple_cartesian<double>
>,CGAL::Arr_halfedge_base<CGAL::Arr_linear_object_2<CGAL::Simple_cartesian<double>
>, CGAL::Arr_face_base>*’make: *** [arrangement.o] Error 1
Does anybody know a way to solve this issue?--
- [cgal-discuss] vertex methods problem, Sterpa, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, Sterpa, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, efif, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, Marco Aurelio Sterpa, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, Efraim Fogel, 09/29/2009
- Re: [cgal-discuss] vertex methods problem, Marco Aurelio Sterpa, 09/29/2009
