- To:
- Subject: Re: [cgal-discuss] vertex methods problem
- Date: Sat, 26 Sep 2009 17:26:40 +0300
Quoting "Marco Aurelio Sterpa"
I use that vector<Halfedge> to save the levels of the arrangements. Anyway
I've to change the structure used to mantain the arrangement while declare
this?
typedef CGAL::Arrangement_2<Traits_2> Arrangement_2;
I meant to say: Why do you maintain a vector of halfedges and not a vector of halfedge handles?
2009/9/26
You cannot access the method vertex(), cause there is no such a method in--
the arrangement halfedge nested class. (The Dcel halfedge does have a method
called vertex()). Please refer to the manual.
Beside, why do you maintain a vector of halfedges and of halfedges handles?
Quoting Sterpa
I've tried also this:
void algorithm_2(vector<Line_2> lines, int k) {
CGAL::Geomview_stream gv(CGAL::Bbox_3(-100, -100, -100, 600, 600,
600));
gv.set_line_width(2);
gv.set_bg_color(CGAL::WHITE);
gv.set_face_color(CGAL::BLACK);
gv.set_vertex_radius(5);
Arrangement_2 arr = getArrangement(lines);
Edge_iterator ei;
vector<Halfedge> levels[lines.size()];
for(ei = arr.edges_begin(); ei != arr.edges_end(); ei++) {
int i = getLevel(*ei, lines);
levels[i].push_back(*ei);
int getLevel(Halfedge e, vector<Line_2> lines) {
int k = 0;
double x;
e.vertex();
and I get the following error:
/usr/local/include/CGAL/Arrangement_on_surface_2.h: In function ‘int
getLevel(Halfedge, std::vector<CGAL::Line_2<CGAL::Simple_cartesian<double>
std::allocator<CGAL::Line_2<CGAL::Simple_cartesian<double> > > >)’:
/usr/local/include/CGAL/Arrangement_on_surface_2.h:736: error: ‘typename
TopTraits_::Dcel::Vertex* CGAL::Arrangement_on_surface_2<GeomTraits_,
TopTraits_>::Halfedge::vertex() [with GeomTraits_ =
CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double> >, TopTraits_ =
CGAL::Arr_unb_planar_topology_traits_2<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
CGAL::Arr_default_dcel<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
> >]’ is privatearrangement.cpp:214: error: within this context
It seems I cannot access the method vertex() of the halfedge structure, so
I
can proceed with this?--
- [cgal-discuss] vertex methods problem, Sterpa, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, Sterpa, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, efif, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, Marco Aurelio Sterpa, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, Efraim Fogel, 09/29/2009
- Re: [cgal-discuss] vertex methods problem, Marco Aurelio Sterpa, 09/29/2009
