- To:
- Subject: Re: [cgal-discuss] vertex methods problem
- Date: Tue, 29 Sep 2009 15:46:39 +0200
Marco Aurelio Sterpa wrote:
> I didn't know it's better to use halfedge_handle to iterate on the edges.
This is not what I said. You have to use an iterator to iterate, and a
Halfedge iterator is convertible to a Halfedge_handle. Anyhow, what I
did say was that it was better to store objects of type Halfedge_handle
rather than objects of type Halfedge.
> 2009/9/26
> <mailto:>>
> Quoting "Marco Aurelio Sterpa"
> <mailto:>>:
> I use that vector<Halfedge> to save the levels of the
> arrangements. Anyway
> I've to change the structure used to mantain the arrangement
> while declare
> this?
> typedef CGAL::Arrangement_2<Traits_2>
> Arrangement_2;
> I meant to say: Why do you maintain a vector of halfedges and not
> a vector of halfedge handles?
> 2009/9/26
> <mailto:>>
> You cannot access the method vertex(), cause there is no
> such a method in
> the arrangement halfedge nested class. (The Dcel halfedge
> does have a method
> called vertex()). Please refer to the manual.
> Beside, why do you maintain a vector of halfedges and of
> halfedges handles?
> Quoting Sterpa
> <mailto:>>:
> I've tried also this:
> void algorithm_2(vector<Line_2> lines, int k) {
> CGAL::Geomview_stream gv(CGAL::Bbox_3(-100,
> -100, -100, 600, 600,
> 600));
> gv.set_line_width(2);
> gv.set_bg_color(CGAL::WHITE);
> gv.set_face_color(CGAL::BLACK);
> gv.set_vertex_radius(5);
> Arrangement_2 arr = getArrangement(lines);
> Edge_iterator ei;
> vector<Halfedge> levels[lines.size()];
> for(ei = arr.edges_begin(); ei !=
> arr.edges_end(); ei++) {
> int i = getLevel(*ei, lines);
> levels[i].push_back(*ei);
> int getLevel(Halfedge e, vector<Line_2> lines) {
> int k = 0;
> double x;
> e.vertex();
> and I get the following error:
> /usr/local/include/CGAL/Arrangement_on_surface_2.h: In
> function ‘int
> getLevel(Halfedge,
> std::vector<CGAL::Line_2<CGAL::Simple_cartesian<double>
> std::allocator<CGAL::Line_2<CGAL::Simple_cartesian<double>
> /usr/local/include/CGAL/Arrangement_on_surface_2.h:736:
> error: ‘typename
> TopTraits_::Dcel::Vertex*
> CGAL::Arrangement_on_surface_2<GeomTraits_,
> TopTraits_>::Halfedge::vertex() [with GeomTraits_ =
> CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
> >, TopTraits_ =
> CGAL::Arr_unb_planar_topology_traits_2<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
> CGAL::Arr_default_dcel<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
> > >]’ is private
> arrangement.cpp:214: error: within this context
> It seems I cannot access the method vertex() of the
> halfedge structure, so
> I
> can proceed with this?--
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- [cgal-discuss] vertex methods problem, Sterpa, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, Sterpa, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, efif, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, Marco Aurelio Sterpa, 09/26/2009
- Re: [cgal-discuss] vertex methods problem, Efraim Fogel, 09/29/2009
- Re: [cgal-discuss] vertex methods problem, Marco Aurelio Sterpa, 09/29/2009
