cgal-discuss - Re : Re : [cgal-discuss] An error when trying to compute intersection of polygons
  • To:
  • Subject: Re : Re : [cgal-discuss] An error when trying to compute intersection of polygons
  • Date: Sun, 27 Sep 2009 07:17:36 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.fr; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=rmCQoGhADPS6JVybktqK66VfNIN/iNyAlhJdK1luLQrkHbWF0u26ZBOgZGqhK7G7R1g5yO/82iCAkd2vMzyEtRZcWJOGIopztn/jr0fI1FaBTT27wU0eHor2gIVowNTOVuXD9I60wAZK/g1ZlahQUCKSvk8kwqch86tCEUHHbgc=;
Hello,
I tried to compute the intersection of the polygons by inserting each polygon apart like this:
std::vector<Polygon_2>        polygons;
// Fill the list of polygons
Initialize the polygon set with a polygon
Polygon_set_2 S(first_polygon);
// Instead of S.intersection(polygons.begin(), polygons.end());
for (int i = 0; i != polygons.size(); ++i)
    S.intersection(polygons[i];
This variation of source code is working fine for the polygons I attached to the previous e-mail. I do not know what is the difference (perhaps in runtime or storage) between the first source code (which didn't work) and the second one?
Thanks
Hichem
De : BBB HHH <>
À :
Envoyé le : Samedi, 26 Septembre 2009, 18h25mn 19s
Objet : Re : [cgal-discuss] An error when trying to compute intersection of polygons
Hello,
Attached to this e-mail, you can find the .dat files storing the polygns i am working with (file first_polygon.dat and files polygon_00.dat to polygon_15.dat). I also attached .off files storing the same polygons so you can visualize them.
Thanks
Hichem
De : "" <>
À :
Envoyé le : Samedi, 26 Septembre 2009, 16h24mn 57s
Objet : Re: [cgal-discuss] An error when trying to compute intersection of polygons
So you are trying to compute the intersection between 'first_polygon' and all the polygons in the range 'polygons.begin(), polygons.end()'. Could you please provide the data that causes the problem. It would be nice if you narrow it down first.
Quoting "BBB HHH" <>:
> Hello,
> I am trying to compute the intersection of some polygons in 2D. For that purpose, i am using the 2D Regularized Boolean Set-Operations of CGAL 3.4. I am also using VS2005 under Windows XP SP3.
> For some polygons which seemto be correct (CCW orientation, non-degenerate, simple, bounded), i have the following error:
> CGAL error: precondition violation!
> _expression_ : cv.is_in_x_range (p)
> File      : c:\program files\cgal-3.4-beta1\include\cgal\arr_segment_traits_2.h
> Line      : 481
> Explanation:
> Refer to the bug-reporting instructions at http://www.cgal.org/bug_report.html
> I am using an exact kernel (CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<Gmpq> >). The problematic line of code is that computing the intersection of some polygons
> // Initialize the polygon set with a polygon
> Thanks in advance for your help
> Hichem Barki
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
--You are currently subscribed to cgal-discuss.
