Re: Re : Re : Re : [cgal-discuss] An error when trying to compute intersection of polygons
- To:
- Subject: Re: Re : Re : Re : [cgal-discuss] An error when trying to compute intersection of polygons
- Date: Sun, 27 Sep 2009 11:43:11 -0400
Hi Hichem,
BBB HHH wrote:
I think the problem is not related to the -frounding-math version because of the successful execution of the second version of source code. Moreover, i am using exact number types.
Wait - I think this does not follow.
IF the CGAL code is correct:
- If rounding math is correct, boolean ops will succeed 100% of the time.
- If ronding math is incorrect, boolean ops will fail < 100% of the time.
In other words, the absence of evidence is not the evidence of absence. I went a few weeks before I realized my rounding math was off...because a lot of the time the code succeeds.
Rounding math affects the exact kernel based on MP_float and quotient. I do not know how it affects gmp-based kernels or any of the filters/wrappers you might put around a kernel.
(My guess is that the lazy-exact-NT wrapper around your kernel might depend on rounding math for it's interval calcs.)
I am not saying here that you have a rounding problem...just that those two conditions (successful execution of the same data with other code and the use of an exact kernel) exactly match the case where I _did_ have a rounding error.
But...that may be moot -- we will see what Efi says.
Actually one thing to try: remove the lazy_exact wrapper from your kernel - just use simple_cartesian<gmpq>. Besides being really slow, does the first code work? :-)
cheers
Ben
- [cgal-discuss] An error when trying to compute intersection of polygons, BBB HHH, 09/25/2009
- Re: [cgal-discuss] An error when trying to compute intersection of polygons, efif, 09/26/2009
- Re : [cgal-discuss] An error when trying to compute intersection of polygons, BBB HHH, 09/26/2009
- Re : Re : [cgal-discuss] An error when trying to compute intersection of polygons, BBB HHH, 09/27/2009
- Re: Re : Re : [cgal-discuss] An error when trying to compute intersection of polygons, Ben Supnik, 09/27/2009
- Re: [cgal-discuss] An error when trying to compute intersection of polygons, Laurent Rineau (GeometryFactory), 09/27/2009
- Re: Re : Re : [cgal-discuss] An error when trying to compute intersection of polygons, efif, 09/27/2009
- Re : Re : Re : [cgal-discuss] An error when trying to compute intersection of polygons, BBB HHH, 09/27/2009
- Re: Re : Re : Re : [cgal-discuss] An error when trying to compute intersection of polygons, Ben Supnik, 09/27/2009
