cgal-discuss - Re: [cgal-discuss] An error when trying to compute intersection of polygons
  • To:
  • Subject: Re: [cgal-discuss] An error when trying to compute intersection of polygons
  • Date: Sun, 27 Sep 2009 16:39:02 +0200
Le dimanche 27 septembre 2009 16:23:55, Ben Supnik a écrit :
> Hi Hichem,
> The order of computation is different - the first (failing) case is I
> think more efficient because the code can use a merge-sort-like sequence.
> You say that your polygons "seem" to be correct...did you use the CGAL
> tests for self-intersection, etc. or a different unrelated set of code
> to check the input data?
> Also, I'm not sure what the MSVC version of -frounding-math is...if the
> low level rounding in CGAL is incorrect, polygon ops can become
> intermittently unreliable...I saw that when I had compiler options
> wrong, and the symptoms were similar.
With recent MSVC, it seems /fp:strict is needed to have reliable IEEE754
floating point arithmetic.
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
