- To:
- Subject: Res: [cgal-discuss] CGAL with QT4 Problem
- Date: Wed, 30 Sep 2009 03:35:19 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.br; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=5VGrFBxCulvEuXVmlFiAoigM/U98wE6Z3zBTm2roIk4dTxB3YU4DHITm4zK7mTACtwBLXQUDvKc5yWBe6Isvf1pB7sMg1GaPJOK6gHyCUYvkriGyhqUbVq+ksGHutx2mJS8caz3TViRKzep+66zyD3TZ93g6ClLDNhb6HQbP+lo=;
Hi, Alex.
Maybe you must install the QT3 too, because some demo asks for the QT3 and other asks for the QT4.
Marcos.
De: alex <>
Para:
Enviadas: Quarta-feira, 30 de Setembro de 2009 6:38:00
Assunto: [cgal-discuss] CGAL with QT4 Problem
Hi
I am trying to make CGAL with QT4 with visual studio 2005. I am configure it correct but it only generate some demo only not all . I want to check Boolean_set_operations_2 demo but it CMake only making ALL_BUILD,INSTALL and ZERO_CHECK project only. No project for demo of Boolean_set_operation_2 . It also doesnot compiles anything.
Can anyone tell me why it causes ?
Alex
-- You are currently subscribed to cgal-discuss.
Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 - Celebridades - Música - Esportes
- [cgal-discuss] Polyhedron rendering in OpenGL, gilles.kneuss, 09/29/2009
- Re: [cgal-discuss] Polyhedron rendering in OpenGL, Laurent Rineau (GeometryFactory), 09/30/2009
- Re: [cgal-discuss] Polyhedron rendering in OpenGL, Amy Tabb, 09/30/2009
- Re: [cgal-discuss] Polyhedron rendering in OpenGL, gilles, 09/30/2009
- [cgal-discuss] How to draw General Polygon_2, alex, 09/30/2009
- [cgal-discuss] CGAL with QT4 Problem, alex, 09/30/2009
- Res: [cgal-discuss] CGAL with QT4 Problem, Marcos R. P., 09/30/2009
- RE: Res: [cgal-discuss] CGAL with QT4 Problem, alex Dowson, 09/30/2009
- Re: [cgal-discuss] Polyhedron rendering in OpenGL, Pierre Alliez, 09/30/2009
