cgal-discuss - [cgal-discuss] Having still problems inheriting CGAL classes ! HELP !
  • To:
  • Subject: [cgal-discuss] Having still problems inheriting CGAL classes ! HELP !
  • Date: Wed, 7 Oct 2009 22:44:33 +0200 (CEST)
Hello,
I found an example of inherited class.
It's in a pdf-file about 2d Triangulations,
from Pierre Alliez and Mariette Yvinec :
Page 55 :
Drawing Generators...
template <class kernel, class TDS>
class DT2 : public CGAL::Delaunay_triangulation_2<kernel,TDS>
public:
void gl_draw_generators()
::glBegin(GL_POINTS);
Point_iterator it;
for(it = points_begin();
it != points_end();
it++)
const Point& p = *it;
::glVertex2f(p.x(),p.y());
::glEnd();
I tried to use the derivated class (DT2) this way :
int main(int argc, char *argv[])
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt;
typedef CGAL::Delaunay_triangulation_2<Gt> Delaunay;
Delaunay* normal=new Delaunay; // Cela fonctionne ( pas d'héritage )
DT2<K,Gt>* heritage=new DT2<K,Gt>(); // Cela provoque une quantité
d'erreur 'no type named...'
The first error is :
/usr/include/CGAL/Triangulation_2.h:77: erreur: no type named ‘size_type’
in ‘class CGAL::Etxy3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >
...followed by lots (of the same type)
I'm really stucked by this problem !
Thanks for help !
Gilles
PS : I'm using gcc under linux.
