- To:
- Subject: Re: [cgal-discuss] Having still problems inheriting CGAL classes ! HELP!
- Date: Wed, 7 Oct 2009 23:20:19 +0200
Re-hello,
my last reply was not as clear as it should be :
DT2<Gt>* heritage=new DT2<Gt>();
or
DT2<K,Gt>* heritage=new DT2<Gt>();
Give the same compile problems (the first error is) :
"main.cpp:23: erreur: wrong number of template arguments (1, should be 2)"
Any other ideas ?
2009/10/7 Gilles Kneuss <>
Hello,
Thank you for so quick response...
I tried to do so :
DT2<Gt>* heritage=new DT2<Gt>(); // Cela provoque une quantité d'erreur 'no type named...'
Also this :
result : main.cpp:23: erreur: wrong number of template arguments (1, should be 2)
Any other ideas ?
Gilles
2009/10/7 Laurent Rineau (GeometryFactory) <>
Le mercredi 07 octobre 2009 22:44:33, a écrit :
... =new DT2<Gt>();> Hello,
> I found an example of inherited class.
> It's in a pdf-file about 2d Triangulations,
> from Pierre Alliez and Mariette Yvinec :
> Page 55 :
> Drawing Generators...
> template <class kernel, class TDS>
> class DT2 : public CGAL::Delaunay_triangulation_2<kernel,TDS>
> public:
> void gl_draw_generators()
> ::glBegin(GL_POINTS);
> Point_iterator it;
> for(it = points_begin();
> it != points_end();
> it++)
> const Point& p = *it;
> ::glVertex2f(p.x(),p.y());
> ::glEnd();
> I tried to use the derivated class (DT2) this way :
> int main(int argc, char *argv[])
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt;
> typedef CGAL::Delaunay_triangulation_2<Gt> Delaunay;
> Delaunay* normal=new Delaunay; // Cela fonctionne ( pas d'héritage )
> DT2<K,Gt>* heritage=new DT2<K,Gt>(); // Cela provoque une quantité
i.e. remove the "K," before "Gt"...
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] Having still problems inheriting CGAL classes ! HELP !, gilles.kneuss, 10/07/2009
- Re: [cgal-discuss] Having still problems inheriting CGAL classes ! HELP!, Laurent Rineau (GeometryFactory), 10/07/2009
- Re: [cgal-discuss] Having still problems inheriting CGAL classes ! HELP!, Gilles Kneuss, 10/07/2009
- Re: [cgal-discuss] Having still problems inheriting CGAL classes ! HELP!, Gilles Kneuss, 10/08/2009
