cgal-discuss - Re: [cgal-discuss] Having still problems inheriting CGAL classes ! HELP!
  • To:
  • Subject: Re: [cgal-discuss] Having still problems inheriting CGAL classes ! HELP!
  • Date: Wed, 7 Oct 2009 23:02:49 +0200
Hello,
Thank you for so quick response...
I tried to do so :
DT2<Gt>* heritage=new DT2<Gt>(); // Cela provoque une quantité d'erreur 'no type named...'
Also this :
DT2<K,Gt>* heritage=new DT2<Gt>();
result : main.cpp:23: erreur: wrong number of template arguments (1, should be 2)
Any other ideas ?
Gilles
2009/10/7 Laurent Rineau (GeometryFactory) <>
Le mercredi 07 octobre 2009 22:44:33, a écrit :
> Hello,
> I found an example of inherited class.
> It's in a  pdf-file about 2d Triangulations,
> from Pierre Alliez and Mariette Yvinec :
> Page 55 :
> Drawing Generators...
> template <class kernel, class TDS>
> class DT2 : public CGAL::Delaunay_triangulation_2<kernel,TDS>
>     public:
>     void gl_draw_generators()
>         ::glBegin(GL_POINTS);
>         Point_iterator it;
>         for(it = points_begin();
>              it != points_end();
>              it++)
>                     const Point& p = *it;
>                     ::glVertex2f(p.x(),p.y());
>         ::glEnd();
> I tried to use the derivated class (DT2) this way :
> int main(int argc, char *argv[])
>     typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
>     typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt;
>     typedef CGAL::Delaunay_triangulation_2<Gt> Delaunay;
>     Delaunay* normal=new Delaunay;     // Cela fonctionne ( pas d'héritage )
>     DT2<K,Gt>* heritage=new DT2<K,Gt>();   // Cela provoque une quantité
... =new DT2<Gt>();
i.e. remove the "K," before "Gt"...
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D
Engineer at GeometryFactory
http://www.geometryfactory.com/
