cgal-discuss - Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection
  • To:
  • Subject: Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection
  • Date: Wed, 14 Oct 2009 15:46:11 +0200
Andre Massing wrote:
Dear all,
since we started to use CGAL in our mesh library part of our DOLFIN fem
library, I came across with another missing intersection detection, this
time in case of a Triangle_3 Tetrahedron_3 intersection, concerning the
Triangle_3_Tetrahedron_3_do_intersect.h file.
Greetings,
Andre Massing
Hi Andre,
I didn't get a close look on your problem, but i see you are using a non-filtered kernel (Simple_cartesian<double>). If you switch to a filtered kernel (e.g. CGAL::Exact_predicates_inexact_constructions_kernel), you should avoid such failures (your attached file runs ok with epic kernel).
Best,
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
