Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection
- To:
- Subject: Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection
- Date: Mon, 26 Oct 2009 14:34:24 +0100
Hi again,
sorry for bothering again the cgal-ml, but this time I came up with a rather simple example, where the Simple_cartesian<double> kernel and Triangle_3_Tetrahedron_3_do_intersect.h might not work "properly". This time the intersection is a vertex point of both the triangle and the tetrahedron and gives again the exception (with debug code):
Triangle points:
Point 1: 0.2 0 0
lies on bounded side of tet: -1
Point 2: 0.2 0.1 0
Point 3: 0.3 0.1 0.1
lies on bounded side of tet: 0
Tetraeder points:
Point 1: 0.3 0 0
Point 2: 0.3 0 0.1
Point 4: 0.4 0.1 0.1
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: k.bounded_side_3_object()(tet, tr[0]) == k.bounded_side_3_object()(tet, tr[2])
File: /home/andre/local/include/CGAL/Triangle_3_Tetrahedron_3_do_intersect.h
Line: 80
Therefore I like to reask, why the k.bounded_side_3_object()(,) is in fact not used for detecting these kinds of intersection?
I've already encountered many cases where the triangle and the tetrahedron intersect only on the boundary of the tetrahedron, which was *not* detected by the Triangle_3 - Triangle_3 intersection test, *but* could have been detected by comparing the k.bounded_side_3_object() results.
I understand that predicates of that kernel can not always compute the right result, but why are the k.bounded_side_3_object() results not taken into consideration while trying to detect the intesection?
Kind regards,
Andre
Andre Massing wrote:
Hi Camille,
thanks for the detailed answer and the pointer to the paper!
Camille Wormser wrote:
Yes, that's right, but I started to narrow down the problem from the AABB tree and according to their performance tests runs the Simple_cartesian<double> 2.5 times faster then the CGAL::Exact_predicates_inexact_constructions_kernel.
So I was wondering, whether one could circumvent this problem for former kernel typ by a slight change in the implementation.
Hi Andre,
The problem is the following: it will always be possible to construct cases where the Simple_cartesian<double> kernel fails. That's exactly the reason why Exact_predicates kernels have been created.
O.k. I formulated my question rather clumsy :), of course I don't expect the detection to be watertight for arbitrary cases.
So let me reformulate my question:
One has a *possible* intersection, which could have been detected by
comparing the results of the k.bounded_side_3_object()(,) function,
but was not detected by the triangle triangle intersection test. Both functions can not give a correct detection for all cases using the simple kernel. So is the triangle triangle intersection test in a certain case more reliable than the point tetrahedron intersection detection, that is advisable to throw an exception, if the mentioned situation occurs? Or what is the criterion to choose the one method to be superior to the other?
See the following paper for an introduction to these issues:
@article{kettner2008classroom,
title={{Classroom examples of robustness problems in geometric computations}},
author={Kettner, L. and Mehlhorn, K. and Pion, S. and Schirra, S. and Yap, C.},
journal={Computational Geometry: Theory and Applications},
volume={40},
number={1},
pages={61--78},
year={2008},
publisher={Elsevier}
Thanks, printed out and I will have a detailed look at it!
We are working on your example of triangle-bbox intersection, because in that particular case, where the final intersection point is in fact an input point (in fact, it is a shared vertex of two input triangles), it is reasonnable to expect even the Simple_cartesian<double> kernel to detect it correctly. This is a very specific case, where tweaking the numerical code could make a difference, and allow the users to trade robustness for efficiency (at their own risk!) with the code failing less often.
Ah, ok, thanks for explanation. Is the reasoning also somehow related to the way the detection is dealt with in the above case?
On the other hand, in the new case you are presenting, you are in front of a very generic robustness issue, for which there is no other solution than using an Exact_predicates kernel. In other words, tweaking the computations may help detecting this particular degenerate case, but would create new failures for other such cases.
Oh, good, that is why I asked, since I have unfortunately no clue which kind of cases (and how they are) well balanced out in the code.
For this reason, we are working on improving the triangle-bbox test (and hopefully other similar ones) so that using an inexact kernel does not make them fail in the kind of special cases you presented (previous thread),
Great that you are looking at it!
but we will not work on this new issue you are presenting: this
kind of problem is expected, and inherent to geometric computations.
Kind regards,
Andre
#include <CGAL/Bbox_3.h> //#include <CGAL/Simple_cartesian.h> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <iostream> typedef CGAL::Simple_cartesian<double> K; //typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef K::Point_3 Point_3; typedef K::Segment_3 Segment_3; typedef K::Triangle_3 Triangle_3; typedef K::Tetrahedron_3 Tetrahedron_3; typedef K::Iso_cuboid_3 Iso_cuboid_3; typedef K::Ray_3 Ray_3; typedef K::Line_3 Line_3; typedef CGAL::Bbox_3 Bbox_3; using std::cout; using std::endl; int main() { Point_3 A(0.3,0.0,0.0); Point_3 B(0.3,0.0,0.1); Point_3 C(0.3,0.1,0.1); Point_3 D(0.4,0.1,0.1); Point_3 a(0.2,0.0,0.0); Point_3 b(0.2,0.1,0.0); Point_3 c(0.3,0.1,0.1); Triangle_3 tri_1(a,b,c); Tetrahedron_3 tet_2(A,B,C,D); if (CGAL::do_intersect(tet_2,tri_1)) cout <<"Intersection of Tetraeder with face triangle" << endl; else cout <<"NO Intersection." << endl; return 0; }
- [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Andre Massing, 10/14/2009
- Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Stephane Tayeb, 10/14/2009
- Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Andre Massing, 10/14/2009
- Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Camille Wormser, 10/14/2009
- Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Andre Massing, 10/26/2009
- Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Eric Berberich, 10/26/2009
