cgal-discuss - Re: [cgal-discuss]
Re: [cgal-discuss]
  • To:
  • Subject: Re: [cgal-discuss]
  • Date: Mon, 19 Oct 2009 16:58:11 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=l0daDHvevQuPk5pvnLYM04g9wwl+WsWs3JpA3gMLoqveI+7l1gfwbA/tBb9SuuzJIn lRvv2GJDeA981CAaCYgw4OaEOB6rEFJa3we5r7F4ZHdgvtHX+9/crZkIdxdm4R+XfezE S59X/eAWZP0H44WOKAvuuV5rhyAcdTXKvC6Sg=
I didnt' specify some information cause I thought to be in the same discussion of last time where I specified them. Anyway I figure out that the problem was just a bad assignment of line in a vector which gives degenerate lines sometimes. That problem was happened because of an undefined y value corresponding to the x used to call the function. Best regards
2009/10/19 Ariel Baez <>
Whew...I was about to ask what type of object I is.
AB
On Mon, Oct 19, 2009 at 10:44 AM, Laurent Rineau (GeometryFactory) <> wrote:
On Monday 19 October 2009 16:16:41 Sterpa wrote:
> I got a floating point exception on the second line of this code:
> NT y = l.y_at_x(v_ij.x());
> NT tmp = v_ij.y() - y;
> v_ij is a Point_2 object made with exact_predicates. Any suggestion about
>  this?
Please read that page:
 http://www.cgal.org/bug_report.html
I do not think anybody here has a crystal ball powerful enough to understand
what sort of "floating point exception" you could have with the tiny piece of
code you gave us!
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
