- To:
- Subject: Re: [cgal-discuss] Next Face
- Date: Tue, 27 Oct 2009 13:06:54 +0100
Perhaps making use of the Facet_iterator "fit" that you increment, would have the desired effect?
As in: print_faceVertices( &fit );
And to be sure to grab only bounded faces, use bounded_faces_begin() and bounded_faces_end().
Then, be sure to read the documentation of vd.bounded_face() to understand why the program do as you
describe.
Sam
On 26 oct. 2009, at 18:43, Marcos R. P. wrote:
VD::Face_iterator fit = vd.faces_begin();
for( ; fit != vd.faces_end(); ++fit )
std::cout << "\nFace " << std::endl;
print_faceVertices( &vd.bounded_face() );
std::cout << std::endl;
}//fim for
- [cgal-discuss], Sterpa, 10/19/2009
- Re: [cgal-discuss], Laurent Rineau (GeometryFactory), 10/19/2009
- Re: [cgal-discuss], Ariel Baez, 10/19/2009
- Re: [cgal-discuss], Marco Aurelio Sterpa, 10/19/2009
- <Possible follow-up(s)>
- [cgal-discuss], Marcos R. P., 10/26/2009
- [cgal-discuss] Next Face, Marcos R. P., 10/26/2009
- Res: [cgal-discuss] Next Face, Marcos R. P., 10/27/2009
- Re: [cgal-discuss] Next Face, Samuel Hornus, 10/27/2009
- Res: Res: [cgal-discuss] Next Face, Marcos R. P., 10/28/2009
- [cgal-discuss], Zohar Levi, 10/29/2009
