- To:
- Subject: Res: [cgal-discuss] Next Face
- Date: Tue, 27 Oct 2009 07:03:52 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.br; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=VXwtnd9RiUzURl8ouTS97vQ1i4lezQFKXaL6K7CCH+mCxH+gzrUlP596/3kRx8Ymh+0kqxVQwMZ230D4uRCLL/dqLNr7FYx11GM4izDa2Nk18uqM3++djWtdZPx3pK9RPGdHegWIZEBIwdkzz85ga2V+zUhNzpwR9OFPeTxH2bg=;
Hi!
The command line:
VD::Face_iterator fit = vd.bounded_faces_begin();
Lead me to error:
PLoc.cpp(83) : error C2440: 'initializing' : cannot convert from 'CGAL::VoronoiDiagram_2::Internal::Face_iterator_adaptor<VDA,Base_it>' to 'CGAL::VoronoiDiagram_2::Internal::Face_iterator_adaptor<VDA,Base_it>'
Some hint?
De: Samuel Hornus <>
Para:
Enviadas: Ter, Outubro 27, 2009 9:06:54 AM
Assunto: Re: [cgal-discuss] Next Face
Perhaps making use of the Facet_iterator "fit" that you increment, would have the desired effect?
As in: print_faceVertices( &fit );
And to be sure to grab only bounded faces, use bounded_faces_begin() and bounded_faces_end().
Then, be sure to read the documentation of vd.bounded_face() to understand why the program do as you
describe.
Sam
On 26 oct. 2009, at 18:43, Marcos R. P. wrote:
> VD::Face_iterator fit = vd.faces_begin();
> for( ; fit != vd.faces_end(); ++fit )
> std::cout << "\nFace " << std::endl;
> print_faceVertices( &vd.bounded_face() );
> std::cout << std::endl;
> }//fim for
--You are currently subscribed to cgal-discuss.
Para:
describe.
Sam
> }//fim for
Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 - Celebridades - Música - Esportes
- [cgal-discuss], Sterpa, 10/19/2009
- Re: [cgal-discuss], Laurent Rineau (GeometryFactory), 10/19/2009
- Re: [cgal-discuss], Ariel Baez, 10/19/2009
- Re: [cgal-discuss], Marco Aurelio Sterpa, 10/19/2009
- <Possible follow-up(s)>
- [cgal-discuss], Marcos R. P., 10/26/2009
- [cgal-discuss] Next Face, Marcos R. P., 10/26/2009
- Res: [cgal-discuss] Next Face, Marcos R. P., 10/27/2009
- Re: [cgal-discuss] Next Face, Samuel Hornus, 10/27/2009
- Res: Res: [cgal-discuss] Next Face, Marcos R. P., 10/28/2009
- [cgal-discuss], Zohar Levi, 10/29/2009
