- To:
- Subject: Re: Re: [cgal-discuss] installing boost (problem)
- Date: Sun, 25 Oct 2009 14:40:58 +0100 (CET)
Hi,
thanks for your help, but i didnt understand so well what i have to do to
solve
the problem! My CMakeLists.txt just have this six line weird text:
# just install the modules
INSTALL_FILES(${CMAKE_DATA_DIR}/Templates .*\\.in)
INSTALL_FILES(${CMAKE_DATA_DIR}/Templates .*\\.txt)
INSTALL_FILES(${CMAKE_DATA_DIR}/Templates .*\\.cmake$)
INSTALL_FILES(${CMAKE_DATA_DIR}/Templates .*\\.dsptemplate$)
INSTALL_FILES(${CMAKE_DATA_DIR}/Templates .*\\.vsmacros$)
About your other solution (downloading the windows installer of boost
1.38)...that was my first try. But it didnt work also, because of some
transfer
errors during the setup.
Thanks
Regards
- [cgal-discuss] installing boost (problem), cristovao_jdc, 10/24/2009
- Re: [cgal-discuss] installing boost (problem), Olivier Tournaire, 10/24/2009
- Re: Re: [cgal-discuss] installing boost (problem), cristovao_jdc, 10/25/2009
- Re: Re: [cgal-discuss] installing boost (problem), Olivier Tournaire, 10/25/2009
- Re: Re: Re: [cgal-discuss] installing boost (problem), cristovao_jdc, 10/25/2009
- Re: [cgal-discuss] installing boost (problem), Laurent Rineau (GeometryFactory), 10/25/2009
