- To:
- Subject: Re: [cgal-discuss] How to install Tacus for CGAL in Fedora 11
- Date: Mon, 2 Nov 2009 14:27:56 +0100
Le lundi 02 novembre 2009 14:20:24,
a écrit :
> Hi,there! I have encounter a problem when install CGAL 3.5. I fail to
> install Tacus for CGAL. My operation system is Fedora 11.And the version
> of GCC in my system is 4.4.0,but as the installation manual of CGAL 3.5
> said , the complier should be Gnu g++ 4.0, 4.1, 4.2, 4.3 .Does it mean
> cgal cannot support my GCC 4.4 or higher version?How can I solve this
> problem?
The installation manual is wrong. I forgot to update it the day I updated
http://www.cgal.org/platforms.html
CGAL-3.5 has been tested successfully with g++-4.4, and that compiler is
supported.
Taucs is a different library. It was not created by CGAL developers, but
eventually has been maintained by a CGAL developer, since CGAL-3.2 if I
remember well. What sort of problem do you have with it under Fedora 11?
Laurent Rineau, PhD
Release Manager of the CGAL Project
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] How to install Tacus for CGAL in Fedora 11, zengdeshou, 11/02/2009
- Re: [cgal-discuss] How to install Tacus for CGAL in Fedora 11, Laurent Rineau (GeometryFactory), 11/02/2009
- Re: Re: [cgal-discuss] How to install Tacus for CGAL in Fedora 11, zengdeshou, 11/02/2009
