- To:
- Subject: Re: Re: [cgal-discuss] How to install Tacus for CGAL in Fedora 11
- Date: Mon, 2 Nov 2009 15:39:59 +0100 (CET)
It still doesn't work,like this:
[root@swordsman
taucs_full]# ./configure
cc -o configurator/configurator configurator/taucs_config.c
rm -rf lib/linux/*
rm -rf obj/linux/*
rm -rf bin/linux/*
rm -rf lib/linux/*.*
rm -rf obj/linux/*.*
rm -rf bin/linux/*.*
rm -rf build/linux/taucs_config_tests.h
rmdir obj/linux/
rmdir bin/linux/
rmdir lib/linux/
[root@swordsman
taucs_full]# make
mkdir obj
mkdir: 无法创建目录 “obj”: 文件已存在
make: [obj/linux/exists.log] 错误 1 (忽略)
mkdir obj/linux/
echo exists > obj/linux/exists.log
cc -c -O3 -Wall -std=c99 -DMACHTYPE_ -I src/ -I build/linux/ -I
external/src/
progs/taucs_blas_underscore_test.c \
-o ./obj/linux/taucs_blas_underscore_test.o
cc \
-o ./obj/linux/taucs_blas_underscore_test \
obj/linux/taucs_blas_underscore_test.o -L external/lib/linux
-llapack
-L external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux -lmetis
-lg2c -lm
obj/linux/taucs_blas_underscore_test build/linux/taucs_config_tests.h
obj/linux/taucs_blas_underscore_test: error while loading shared libraries:
libg2c.so.0: cannot open shared object file: No such file or directory
make: [build/linux/taucs_config_tests.h] 错误 127 (忽略)
external/src/
progs/taucs_blas_nounderscore_test.c \
-o ./obj/linux/taucs_blas_nounderscore_test.o
cc \
-o ./obj/linux/taucs_blas_nounderscore_test \
obj/linux/taucs_blas_nounderscore_test.o -L external/lib/linux
-llapack -L external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux
-lmetis -lg2c -lm
obj/linux/taucs_blas_nounderscore_test.o: In function `main':
taucs_blas_nounderscore_test.c:(.text+0xa4): undefined reference to `dgemm'
collect2: ld 返回 1
make: [build/linux/taucs_config_tests.h] 错误 1 (忽略)
obj/linux/taucs_blas_nounderscore_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_blas_nounderscore_test:命令未找到
external/src/
progs/taucs_blas_cblaswrap_test.c \
-o ./obj/linux/taucs_blas_cblaswrap_test.o
cc \
-o ./obj/linux/taucs_blas_cblaswrap_test \
obj/linux/taucs_blas_cblaswrap_test.o -L external/lib/linux -llapack
-lg2c -lm
obj/linux/taucs_blas_cblaswrap_test.o: In function `main':
taucs_blas_cblaswrap_test.c:(.text+0xa4): undefined reference to `f2c_dgemm'
collect2: ld 返回 1
obj/linux/taucs_blas_cblaswrap_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_blas_cblaswrap_test:命令未找到
external/src/
progs/taucs_c99_complex_test.c \
-o ./obj/linux/taucs_c99_complex_test.o
cc \
-o ./obj/linux/taucs_c99_complex_test \
obj/linux/taucs_c99_complex_test.o -L external/lib/linux -llapack -L
-lg2c -lm
obj/linux/taucs_c99_complex_test build/linux/taucs_config_tests.h
obj/linux/taucs_c99_complex_test: error while loading shared libraries:
external/src/
progs/taucs_cilk_test.c \
-o ./obj/linux/taucs_cilk_test.o
progs/taucs_cilk_test.c:8:19: 错误:cilk.h:没有那个文件或目录
progs/taucs_cilk_test.c:10: 警告:忽略 #pragma lang
progs/taucs_cilk_test.c:12: 错误:expected ‘=’, ‘,’, ‘;’,
‘asm’ or ‘__attribute__’ before ‘int’
progs/taucs_cilk_test.c:17: 错误:expected ‘=’, ‘,’, ‘;’,
cc \
-o ./obj/linux/taucs_cilk_test \
obj/linux/taucs_cilk_test.o -L external/lib/linux -llapack -L
-lg2c -lm
cc: obj/linux/taucs_cilk_test.o:没有那个文件或目录
obj/linux/taucs_cilk_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_cilk_test:命令未找到
mkdir bin
mkdir: 无法创建目录 “bin”: 文件已存在
make: [bin/linux/exists.log] 错误 1 (忽略)
mkdir bin/linux/
echo exists > bin/linux/exists.log
mkdir lib
mkdir: 无法创建目录 “lib”: 文件已存在
make: [lib/linux/exists.log] 错误 1 (忽略)
mkdir lib/linux/
echo exists > lib/linux/exists.log
external/src/
-DTAUCS_CORE_GENERAL \
src/taucs_sn_llt.c \
-o ./obj/linux/taucs_sn_llt.o
在包含自 src/taucs_sn_llt.c:13 的文件中:
src/taucs.h:6:32: 错误:taucs_config_tests.h:没有那个文件或目录
src/taucs.h:83:2: 错误:#error "taucs_blas_*_test: linking with the BLAS
failed all attempts"
In file included from src/taucs_sn_llt.c:13:
src/taucs.h:837:
错误:‘taucs_blas_name’声明为返回一个函数的函数
src/taucs.h:837: 警告:函数声明中出现形参名却未指定类型
src/taucs.h:838:
src/taucs.h:838: 警告:函数声明中出现形参名却未指定类型
src/taucs.h:839:
src/taucs.h:839: 警告:函数声明中出现形参名却未指定类型
src/taucs.h:840:
src/taucs.h:840: 警告:函数声明中出现形参名却未指定类型
make: *** [obj/linux/taucs_sn_llt.o] 错误 1
- [cgal-discuss] How to install Tacus for CGAL in Fedora 11, zengdeshou, 11/02/2009
- Re: [cgal-discuss] How to install Tacus for CGAL in Fedora 11, Laurent Rineau (GeometryFactory), 11/02/2009
- Re: Re: [cgal-discuss] How to install Tacus for CGAL in Fedora 11, zengdeshou, 11/02/2009
