cgal-discuss - Re: [cgal-discuss] How to install Tacus for CGAL in Fedora 11
  • To:
  • Subject: Re: [cgal-discuss] How to install Tacus for CGAL in Fedora 11
  • Date: Mon, 2 Nov 2009 15:57:21 +0100
Le lundi 02 novembre 2009 15:39:59,
a écrit :
> It still doesn't work,like this:
> [root@swordsman
> taucs_full]# ./configure
> cc -o configurator/configurator configurator/taucs_config.c
> rm -rf lib/linux/*
> rm -rf obj/linux/*
> rm -rf bin/linux/*
> rm -rf lib/linux/*.*
> rm -rf obj/linux/*.*
> rm -rf bin/linux/*.*
> rm -rf build/linux/taucs_config_tests.h
> rmdir obj/linux/
> rmdir bin/linux/
> rmdir lib/linux/
> [root@swordsman
> taucs_full]# make
> mkdir obj
> mkdir: 无法创建目录 “obj”: 文件已存在
> make: [obj/linux/exists.log] 错误 1 (忽略)
> mkdir obj/linux/
> echo exists > obj/linux/exists.log
> cc -c -O3 -Wall -std=c99 -DMACHTYPE_ -I src/ -I build/linux/ -I
> external/src/ \
> progs/taucs_blas_underscore_test.c \
> -o ./obj/linux/taucs_blas_underscore_test.o
> cc \
> -o ./obj/linux/taucs_blas_underscore_test \
> obj/linux/taucs_blas_underscore_test.o -L external/lib/linux
> -llapack
> -L external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux
> -lmetis -lg2c -lm
> obj/linux/taucs_blas_underscore_test build/linux/taucs_config_tests.h
> obj/linux/taucs_blas_underscore_test: error while loading shared libraries:
> libg2c.so.0: cannot open shared object file: No such file or directory
The error is here. You miss libg2c.so.0. The solution is to install compat-
libf2c-34:
sudo yum install compat-libf2c-34
Next time, try to post error log in English, please. You are lucky that I
could understand the problem without the need to read the error messages. :-)
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
