cgal-discuss - Re: [cgal-discuss] Edge with info
  • To:
  • Subject: Re: [cgal-discuss] Edge with info
  • Date: Tue, 03 Nov 2009 11:52:58 +0100
Dear Daniel,
unfortunately this cannot work because
tds.incident_cells( Edge e)
currently starts at e->first.
Anyway as it is not documented it could change in further releases even though this is not very probable.
Best
Manuel
Daniel Duque wrote:
Hello,
I am thinking about efficiently adding info to the edges of a triangulation. E.g., imagine you frequently need their lengths, and do not want to compute them each time you need them, just once when the triangulation is built.
Since edges are not explicitly represented, I had the idea of using
Cell_circulator tds.incident_cells ( Edge e) Starts at an arbitrary cell incident to e
to get one cell incident to an edge. The cell could be provided with info relevant to the edge. E.g., a simple way would be to keep a 4x4 matrix, with element i,j giving the info for the vertex with indices i,j.
My question is if this approach is (basically) sensible.
Also, I am assuming the "arbitrary" cell will always be the same one for a given edge. I would be surprised if this was not the case.
BTW, there was a previous email from "400555 < >" about this last July, but it did not get any answers.
Best regards,
Daniel
