- To:
- Subject: Re: [cgal-discuss] Edge with info
- Date: Tue, 3 Nov 2009 13:19:06 +0100
- Organization: UPM
Hello,
> If I've understood your approach right you will end up storing the
> information in each of the incident cells of an edge, right? This might
> cause non-negligible memory overhead.
Yes, my idea is a waste of memory.
> As Sylvain suggested you can of course trade memory overhead against
> running time using a map.
Of course, the all-powerful STD map! That is clearly the way to go (CPU time
is not an issue, the bottleneck is somewhere else, and is at least O(N)^2 or
so).
Thanks, everyone
Daniel
Nueva dirección de e-mail!
- [cgal-discuss] Edge with info, Daniel Duque, 11/03/2009
- Re: [cgal-discuss] Edge with info, Manuel Caroli, 11/03/2009
- Re: [cgal-discuss] Edge with info, Daniel Duque, 11/03/2009
- Re: [cgal-discuss] Edge with info, Vitaliy, 11/03/2009
- Re: [cgal-discuss] Edge with info, Sylvain Pion, 11/03/2009
- Re: [cgal-discuss] Edge with info, Shuchu Han, 11/03/2009
