cgal-discuss - Re: [cgal-discuss] Edge with info
  • To:
  • Subject: Re: [cgal-discuss] Edge with info
  • Date: Tue, 03 Nov 2009 12:57:19 +0100
Daniel Duque wrote:
On Tuesday 03 November 2009 11:52:58 Manuel Caroli wrote:
Dear Daniel,
unfortunately this cannot work because
tds.incident_cells( Edge e)
currently starts at e->first.
Right, I could simply load the info onto the cell e->first. Why wouldn't this work? Every edge would have an e->first with its info, would it not?
ok, of course this would work. But then why to use tds.incident_cells(Edge e)?
If I've understood your approach right you will end up storing the information in each of the incident cells of an edge, right? This might cause non-negligible memory overhead.
As Sylvain suggested you can of course trade memory overhead against running time using a map.
best
Manuel
If there are flips things can get messy, but I would load the info _after_ the triangulation is built, not _while_ it builds...
Thanks for the anwers!
Best,
Daniel
