cgal-discuss - Re: [cgal-discuss] efficiency of a O(n^2) algorithm
  • To:
  • Subject: Re: [cgal-discuss] efficiency of a O(n^2) algorithm
  • Date: Thu, 5 Nov 2009 18:43:26 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=IDyENMam18LS1aOc9S+AA23VMUOFzXeoZ2hxYZflM1wfRnQeZAtCSkdl9f+NgGwFEQ fGhPpwqfcx4djRhyt7Qd51fefMJpPasIby/9JoHwwV8TSxHKR7oMrelIyaG/KIY9Rx6e y5dS3xgGQTRiVd98ujbt3aVBe4wtb2ptiXmiQ=
I just consider simple arrangements, so every line intersect each other in exactly one point, I don't know if this can help. Anayway what I have to compute is the set of k-levels for a given arrangement, this is a simple O(n^2) algorithm, but I guess there's another randomized with better complexity. Do you know is something offered by the library to do this stuff? This is part of a little bigger algorithm and it seems that this for iteration is the one who takes the longest time to compute.
2009/11/5 Ben Supnik <>
Hi Sterpa,
I'm not entirely sure I understand what's going on here, but it looks to me like the slow part is running a zone insertion simulation for many lines, since each zone insertion is slow....you would be O(l * n) where L is the number of lines and n is the number of operations the zone insertion produces...(which is at least linear for something).
If your lines don't overlap, you could perhaps use a sweep operation to simply insert the lines into the arrangement.  For large numbers of lines and a not-insanely-huge arrangement, this would give you faster processing O nlogn more or less.  (The only time this is slower is if the lines are few and the arrangement is huge, such that the walking locator mostly ignores the arrangement.)
You could use a curve with data attached to then recover from the swept arrangement what edges are in the arrangement, what were your input lines and what were both.
You would have to do an O(N) pass over the TOTAL arrangement to find the lines where N is every edge in the arrangement, not just the inserted ones...so again depending on your arrangements the size of a different N might be worse than the advantage of lower time complexity.
cheers
Ben
Sterpa wrote:
       Arrangement_2 arr = getArrangement(lines);
       Arr_walk walk = Arr_walk(arr);
       sort(lines.begin(), lines.end(), lineComparison);
       for(int i = 0;i < lines.size();i++) {
               Line_2 l_1 = lines[i];
               std::vector<CGAL::Object> list;
               Face_handle face;
               Vertex_handle vertex;
               Halfedge_handle halfedge;
               CGAL::zone(arr, l_1, std::back_inserter(list), walk);
               int level = i;
               if(assign(halfedge, list[0]))
levels[level].push_back(*halfedge);
               for(int j = 2;j < list.size();j += 2) {
                       if(assign(halfedge, list[j])) {
                               if(halfedge->curve().line() == l_1) {
                                       Vertex_handle v = halfedge->source();
                                      Arrangement_2::Halfedge_around_vertex_circulator circ =
v->incident_halfedges();                                        while(circ->curve().line() == l_1)
circ++;
                                       Line_2 l_2 = circ->curve().line();
                                       Point_2 p = v->point();
                                       NT x = p.x() + 1;
                                      if(!halfedge->target()->is_at_open_boundary()) x = CGAL::midpoint(p,
halfedge->target()->point()).x();
                                       Line_2 l_vertical = Line_2(-1, 0, x);
                                       Point_2 p_1 = intersection(l_1,
l_vertical);
                                       Point_2 p_2 = intersection(l_2,
l_vertical);
                                       if(p_1.y() < p_2.y()) level--;
                                       else level++;
I have this piece of code and I'm performing some tests over it, but with 500
lines this algorithm takes about 1minute, is there any way to improve the
performance? The complexity of this code is O(n^2) so I'd expect a little more
than just ordering 500 lines (which is O(n logn)) but not so much.
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
