cgal-discuss - Re: [cgal-discuss] efficiency of a O(n^2) algorithm
  • To:
  • Subject: Re: [cgal-discuss] efficiency of a O(n^2) algorithm
  • Date: Thu, 05 Nov 2009 13:09:49 -0500
Hi,
Marco Aurelio Sterpa wrote:
I've used this definition for numeric type, can the running time depends by this?
typedef CGAL::Exact_predicates_exact_constructions_kernel_with_sqrt Kernel_2;
typedef Kernel_2::FT NT;
Yes and no. That kernel may be unnecessarily slow...you might get more speed with a faster one, but the fundamental O(N^2) of the algorithm isn't going to go away even if you use a faster kernel. I don't think any of the kernels have faster than constant-time operations but I am not sure about this. You may want to try a filtered kernel or NT or something...for my project I simply tried some common ops with a whole range of kernels and picked the fastest one that met my numeric needs (exact ctors) as measured on real data. :)
