cgal-discuss - Re: [cgal-discuss] Keeping track of boundary edges
  • To:
  • Subject: Re: [cgal-discuss] Keeping track of boundary edges
  • Date: Thu, 19 Nov 2009 14:38:20 +0100
  • Organization: UPM
On Thursday 19 November 2009 12:47:26 Josip Dzolonga wrote:
> Thanks, wouldn't something like std::pair<Point, Point> be nicer since
> Vertex handles are again bound to cells?
You would then need a std::map<pppair,info>, where pppair is a
std::pair<Point, Point>. Then, check whether two points are "close" (equality
can be tricky, that depends on the kernel).
It should work, but I think I prefer the std::map<edge,info> way...
Best,
Daniel
, that way you may access each vertex
> > uniquely. It
> > works just fine.
> > Best,
> > Daniel
> > On Thursday 19 November 2009 02:40:46 Josip Dzolonga wrote:
> > > Hello,
> > > I am growing a region (on a 3D Delaunay triangulation), starting from
> > > one seed facet and then joining some of its neighbouring facets etc. To
> > > accomplish this I want to be able to keep the boundary edges in a set,
> > > however I might end up with different entries of the same edge because
> > > it can be accessed from different cells. Is there any way I can
> > > represent
> > them
> > > uniquely?
> > > Josip
> > Nueva dirección de e-mail!
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
