- To:
- Subject: Re: [cgal-discuss] Keeping track of boundary edges
- Date: Thu, 19 Nov 2009 15:21:55 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=gL2Qa15zYdzF/YSIMX14d1ilYGmQqyIBNbVa8ni14aOn8QlzhDbPIN4XtmZQpJKThy kydDKbe/F1Adzbp8I43gDXhCwHEK/zeSivI60UVs4Ui6BGcB52TGZwYREcb5qx7rlOAJ hgp16qsmH7JT9ZoF2oaULOWOnlEIxqZCGEDnA=
We're using an exact predicates kernel, so that should not be an issue :) Thanks you !
On Thu, Nov 19, 2009 at 2:38 PM, Daniel Duque <> wrote:
On Thursday 19 November 2009 12:47:26 Josip Dzolonga wrote:You would then need a std::map<pppair,info>, where pppair is a
> Thanks, wouldn't something like std::pair<Point, Point> be nicer since
> Vertex handles are again bound to cells?
std::pair<Point, Point>. Then, check whether two points are "close" (equality
can be tricky, that depends on the kernel).
It should work, but I think I prefer the std::map<edge,info> way...
Best,
Daniel
, that way you may access each vertex
> > uniquely. It
> > works just fine.
> > Best,
> > Daniel
> > On Thursday 19 November 2009 02:40:46 Josip Dzolonga wrote:
> > > Hello,
> > > I am growing a region (on a 3D Delaunay triangulation), starting from
> > > one seed facet and then joining some of its neighbouring facets etc. To
> > > accomplish this I want to be able to keep the boundary edges in a set,
> > > however I might end up with different entries of the same edge because
> > > it can be accessed from different cells. Is there any way I can
> > > represent
> > them
> > > uniquely?
> > > Josip
> > Nueva dirección de e-mail!
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Keeping track of boundary edges, Josip Dzolonga, 11/19/2009
- Re: [cgal-discuss] Keeping track of boundary edges, Andreas Fabri, 11/19/2009
- Re: [cgal-discuss] Keeping track of boundary edges, Daniel Duque, 11/19/2009
- Re: [cgal-discuss] Keeping track of boundary edges, Josip Dzolonga, 11/19/2009
