cgal-discuss - Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3
  • To:
  • Subject: Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3
  • Date: Thu, 19 Nov 2009 17:10:43 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=xON/gj3Yr0Bhh5tV7MnmiAVH4eSWzCx62H4Aa9MElRG0FLvDv194o9UZ8HckpTOymQ L6/GXNEtyqUikocbdNybtfxzNBlkzKsNTfkQLOo8BcEXbNLoL3Zml8S/5zt8k8FWYUGt 0U6txPgXy5pZyOtufPdca/JWKU4cvNUCH66PY=
Hello everyone again :),
I have started constructing a minimal counterexample and noticed that the problem arises when I try to "dereference" a Facet_circulator. Namely this piece of code
// current - edge, best - facet
Facet_circulator c = T.incident_facets(current, best);
Facet_circulator d(c);
std::list<Facet> candidates;
do {
                std::cout << "1\n";
                *c;
                std::cout << "2\n";
} while(++c != d);
The 1 prints and then I get the assertion error described in the previous e-mail. I couldn't find any preconditions that a Facet_circulator has to satisfy before being dereferenced. Any ideas? I am aware that this code piece does not provide enough information for the problem, however I was just curious if this is a common problem;
Best,
Josip
On Sun, Nov 15, 2009 at 10:30 PM, Josip Dzolonga <> wrote:
is_valid() succeeds both before and after the loop. The kernel is exactly that one, Exact_predicates_inexact_constructions_kernel. I will try to come up with a minimal (as minimal as possible) example that crashes and post it.
Thank you all for the help,
Josip
On Sun, Nov 15, 2009 at 10:23 PM, Andreas Fabri <> wrote:
ok, I missed the 'break'.
The code sniplet you show should be ok then, so my guess
is that you there is some bug earlier.
Just the usual question: Do uou use an Exact_predicates_inexact_constructions_kernel
or something comparable ?
Add assert(T.is_valid()); right before the for loop.
andreas
Josip Dzolonga wrote:
I was referring to this
while(!seen.empty()) {
         for(Finite_vertices_iterator vit = T.finite_vertices_begin();
               vit != T.finite_vertices_end(); ++vit) {
               if(seen.find(vit->point()) != seen.end()) {
                   seen.erase(vit->point());
                   T.remove(vit);
                   break;
I break the loop after a point is removed. I also tried the code that you provided, but that unfortunately did not solve the problem.
Best,
Josip
On Sun, Nov 15, 2009 at 10:08 PM, Andreas Fabri < <mailto:>> wrote:
   Hi Josip,
   I am not sure you understood my explanantion, but it can also be
   that I didn't understand yours.
   It is a mistake to do the ++vit, AFTER having called T.remove(vit),
   and that is what your for loop does.
   My version makes a copy of thr iterator, advances the iterator
   and only then removes the vertex.
   andreas
       Hi Andreas,
       I corrected myself in my latest reply, but that did not solve
       the problem.
       Josip
       On Sun, Nov 15, 2009 at 9:07 PM, Andreas Fabri
       <mailto:>
       <mailto:
       <mailto:>>> wrote:
          Hi Josip,
          You shouldn't expect that ++vit works correctly after that
       you called
          T.remove(vit).
          You better write this
                          vit != T.finite_vertices_end();) {
                              Vertex_handle vh = vit;
                              ++vit;
                              T.remove(vh);
                              break;
          Note that the same would be true for a std::list.
          andreas
              Hi Nico,
              I thought of that, but at no point I am reusing old cell
              handles/vertex handles. I thought that while removing them, I
              might be causing the problem - but even if I change to
       code to
              the following, the problems remains
                                 T.remove(vit);
                                 break;
              That is, I am iterating again over all vertices.
              Thanks,
              Josip
              On Sun, Nov 15, 2009 at 8:42 PM, Nico Kruithof
              < <mailto:>
       <mailto: <mailto:>>
              <mailto:
       <mailto:> <mailto:
       <mailto:>>>>
              wrote:
                 Hi Josip,
                 The assertion says that the vertex is not contained in
       the Cell.
                 When you remove vertices, cells get removed and added when
                 re-triangulating. Internally, CGAL will reuse the
       memory of
              deleted
                 cells for the new cells. This might be the reason you
       are getting
                 the assertion.
                 -- Nico
                 On Sun, Nov 15, 2009 at 6:26 PM, Josip Dzolonga
              < <mailto:>
       <mailto: <mailto:>>
                 <mailto:
       <mailto:> <mailto:
       <mailto:>>>> wrote:
                     Hello everyone,
                     I am trying to remove some certain points from the
       Delaunay
                     triangulation. I had some problems even before,
       and got some
                     advice from here, but the problem still pertains. The
                     problematic code follows
       seen.end()) {
                                     T.remove(vit);
                     Where seen is of type std::set<Point> and has been
       already
                     filled. Later on when I try to use the
       triangulation, I
              get the
                     following error
                     CGAL error: assertion violation!
                     Expr: v == V[3]
                     File: /usr/include/CGAL/Triangulation_ds_cell_base_3.h
                     Line: 98
                     terminate called after throwing an instance of
              'std::logic_error'
                       what():  basic_string::_S_construct NULL not valid
                     Aborted
                     Which comes from the function  int index(const
       Vertex_handle&
                     v). I can not remove the same vertex twice, since I am
              iterating
                     over the finite vertices and this is the only
       place where
              vertex
                     removal is taking place. Any ideas would be highly
              appreciated!
                     Best,
                     Josip
          --    You are currently subscribed to cgal-discuss.
