- To:
- Subject: Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3
- Date: Thu, 19 Nov 2009 18:29:53 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=rXutGfHsromqCrzXHtfHk1Pd7NN/P6Y03m6FamAoevf8A8PdCEtqgRsZthw4TYyShT Vbf9dcGvzHzRQOGRjfN2tqa++2mVABlPzGpFBgONYmOUnTw6B9phBR+RqWWcQe2SlgLg rA/aeqsHLap8/lUY18MwzEplwTLMgVFy/qlZo=
I am just removing some vertices. is_valid() succeeds before this happens. I am trying to come up with a minimal example that reproduces this.
Best
Josip
On Thu, Nov 19, 2009 at 6:25 PM, Manuel Caroli <> wrote:
Hi Josip,
your code seems ok. There might be a problem in your triangulation though. Do you do any modifications on the triangulation after its construction? To be sure that your triangulation is ok you might want to run the is_valid function on it right before the below piece of code.
Unfortunately, to be able to say anything more precise we would really need some compilable example that exhibits the problem you describe.
best
Manuel
Josip Dzolonga wrote:
I also forgot to note that I also check if c == 0.
On Thu, Nov 19, 2009 at 5:10 PM, Josip Dzolonga < <mailto:>> wrote:
Hello everyone again :),
I have started constructing a minimal counterexample and noticed
that the problem arises when I try to "dereference" a
Facet_circulator. Namely this piece of code
// current - edge, best - facet
Facet_circulator c = T.incident_facets(current, best);
Facet_circulator d(c);
std::list<Facet> candidates;
do {
std::cout << "1\n";
*c;
std::cout << "2\n";
} while(++c != d);
The 1 prints and then I get the assertion error described in the
previous e-mail. I couldn't find any preconditions that a
Facet_circulator has to satisfy before being dereferenced. Any
ideas? I am aware that this code piece does not provide enough
information for the problem, however I was just curious if this is a
common problem;
Best,
Josip
On Sun, Nov 15, 2009 at 10:30 PM, Josip Dzolonga< <mailto:>> wrote:
is_valid() succeeds both before and after the loop. The kernel
is exactly that one,
Exact_predicates_inexact_constructions_kernel. I will try to
come up with a minimal (as minimal as possible) example that
crashes and post it.
Thank you all for the help,
Josip
On Sun, Nov 15, 2009 at 10:23 PM, Andreas Fabri
<<mailto:>> wrote:
ok, I missed the 'break'.
The code sniplet you show should be ok then, so my guess
is that you there is some bug earlier.
Just the usual question: Do uou use an
or something comparable ?
Add assert(T.is_valid()); right before the for loop.
andreas
I was referring to this
while(!seen.empty()) {
for(Finite_vertices_iterator vit =
T.finite_vertices_begin();
vit != T.finite_vertices_end(); ++vit) {
if(seen.find(vit->point()) != seen.end()) {
seen.erase(vit->point());
T.remove(vit);
break;
I break the loop after a point is removed. I also tried
the code that you provided, but that unfortunately did
not solve the problem.
Best,
Josip
On Sun, Nov 15, 2009 at 10:08 PM, Andreas Fabri
<mailto:><mailto:
<mailto:>>> wrote:
Hi Josip,
I am not sure you understood my explanantion, but it
can also be
that I didn't understand yours.
It is a mistake to do the ++vit, AFTER having called
T.remove(vit),
and that is what your for loop does.
My version makes a copy of thr iterator, advances the
iterator
and only then removes the vertex.
andreas
Hi Andreas,
I corrected myself in my latest reply, but that
did not solve
the problem.
Josip
On Sun, Nov 15, 2009 at 9:07 PM, Andreas Fabri
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>> wrote:
Hi Josip,
You shouldn't expect that ++vit works
correctly after that
you called
T.remove(vit).
You better write this
vit != T.finite_vertices_end();) {
seen.end()) {
Vertex_handle vh = vit;
++vit;
T.remove(vh);
break;
Note that the same would be true for a std::list.
andreas
Hi Nico,
I thought of that, but at no point I am
reusing old cell
handles/vertex handles. I thought that
while removing them, I
might be causing the problem - but even if
I change to
code to
the following, the problems remains
vit !=
!= seen.end()) {
T.remove(vit);
break;
That is, I am iterating again over all
vertices.
Thanks,
Josip
On Sun, Nov 15, 2009 at 8:42 PM, Nico Kruithof
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>
<mailto:
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>>>
wrote:
Hi Josip,
The assertion says that the vertex is
not contained in
the Cell.
When you remove vertices, cells get
removed and added when
re-triangulating. Internally, CGAL will
reuse the
memory of
deleted
cells for the new cells. This might be
the reason you
are getting
the assertion.
-- Nico
On Sun, Nov 15, 2009 at 6:26 PM, Josip
Dzolonga
<mailto:> <mailto:
<mailto:>>
<mailto:
<mailto:> <mailto:
<mailto:>>>
<mailto:
<mailto:>
<mailto:
<mailto:>>
<mailto: <mailto:>
<mailto:
<mailto:>>>>> wrote:
Hello everyone,
I am trying to remove some certain
points from the
Delaunay
triangulation. I had some problems
even before,
and got some
advice from here, but the problem
still pertains. The
problematic code follows
vit !=
seen.end()) {
T.remove(vit);
Where seen is of type
std::set<Point> and has been
already
filled. Later on when I try to use the
triangulation, I
get the
following error
CGAL error: assertion violation!
Expr: v == V[3]
File:
/usr/include/CGAL/Triangulation_ds_cell_base_3.h
Line: 98
terminate called after throwing an
instance of
'std::logic_error'
what():
basic_string::_S_construct NULL not valid
Aborted
Which comes from the function int
index(const
Vertex_handle&
v). I can not remove the same
vertex twice, since I am
iterating
over the finite vertices and this
is the only
place where
vertex
removal is taking place. Any ideas
would be highly
appreciated!
Best,
Josip
-- You are currently subscribed to
cgal-discuss.
-- You are currently subscribed to cgal-discuss.
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, (continued)
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Andreas Fabri, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Josip Dzolonga, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Sylvain Pion, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Josip Dzolonga, 11/19/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Manuel Caroli, 11/19/2009
