cgal-discuss - Re: [cgal-discuss] Surface reconstruction from point cloud - example code does not compile
  • To: "" <>
  • Cc: "" <>
  • Subject: Re: [cgal-discuss] Surface reconstruction from point cloud - example code does not compile
  • Date: Fri, 20 Nov 2009 11:44:36 +0100
Hi Laurent,
I am using the latest release.
Best,
Engin
Sent from a mobile device. Sorry for typos.
On 20.11.2009, at 09:27, Laurent Saboret <> wrote:
Hi Engin,
Are you using the official CGAL 3.5 release or directly the code in SVN?
Best regards,
Laurent Saboret
Engin Kurutepe wrote:
Hi all,
I am linking against CGAL3.5 and trying to compile the example code from this page: http://www.cgal.org/Manual/last/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html#Subsection_45.3.2
However gcc4.2.1 spits out the following errors:
/Users/ekurutepe/Dropbox/Development/depthRender/depthRender/../../ lib/include/CGAL/Meshes/Triangulation_mesher_level_traits_3.h:76:0 / Users/ekurutepe/Dropbox/Development/depthRender/depthRender/../../ lib/include/CGAL/Meshes/Triangulation_mesher_level_traits_3.h:76: error: no type named 'Locate_type' in 'class CGAL: :Surface_mesh_complex_2_in_triangulation_3< CGAL: :Delaunay_triangulation_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL: :Triangulation_data_structure_3< CGAL: :Surface_mesh_vertex_base_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL: :Triangulation_vertex_base_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL: :Triangulation_cell_base_with_circumcenter_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh_cell
_base_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL: :Triangulation_cell_base_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > >'
/Users/ekurutepe/Dropbox/Development/depthRender/depthRender/../../ lib/include/CGAL/Meshes/Triangulation_mesher_level_traits_3.h:54:0 / Users/ekurutepe/Dropbox/Development/depthRender/depthRender/../../ lib/include/CGAL/Meshes/Triangulation_mesher_level_traits_3.h:54: error: no type named 'Weighted_tag' in 'class CGAL: :Surface_mesh_complex_2_in_triangulation_3< CGAL: :Delaunay_triangulation_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL: :Triangulation_data_structure_3< CGAL: :Surface_mesh_vertex_base_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL: :Triangulation_vertex_base_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL: :Triangulation_cell_base_with_circumcenter_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh_cel
l_base_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL: :Triangulation_cell_base_3< CGAL: :Robust_circumcenter_traits_3< CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > >'
The call causing this error is:
STr tr; // 3D Delaunay triangulation for surface mesh generation
C2t3 c2t3(tr); // 2D complex in 3D Delaunay triangulation
CGAL::make_surface_mesh(c2t3, // reconstructed mesh
surface, // implicit surface
criteria, // meshing criteria
CGAL::Manifold_with_boundary_tag()); // require manifold mesh
When I dug a little deeper into the source code I found out that C2t3 is a typedef for Complex_2_in_triangulation_3 and that Complex_2_in_triangulation_3 indeed does not have the Locate_type and Weighted_tag types. Onthe other hand Locate_type and Weighted_tag are types in Triangulation_3which is NOT a parent class of Complex_2_in_triangulation_3.
Is this an error on my side or did maybe a recent commit break the example code?
Thanks a lot in advance.
Cheers,
Engin Kurutepe.
Engin Kurutepe TU Berlin
FG Nachrichtenübertragung
Tel: +49 30 314 28507 Sekr. EN-1, Einsteinufer 17
Fax: +49 30 314 22514 10587 Berlin Germany
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur destinataire. Si une erreur de transmission ou une adresse erronée a mal dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une réponse par courrier électronique dès réception. Si vous n’êtes pas le destinataire de ce courrier, vous ne devez pas l’utiliser, le conser ver, en faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne sa urait engager de quelque manière que ce soit INFOTERRA France SAS, n i ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely for the use of the addressee. If you have received this e- mail in error please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind INFOTERRA France SAS in any contract or obligation, nor its subsidiaries.
