- To:
- Subject: Re: [cgal-discuss] conversion to non-scalar type requested error.
- Date: Fri, 20 Nov 2009 13:07:58 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=ERo0tAwvZEKKoK+hMHQhIPjK45JmcG1P+m3/kFogB0YjYqoB0G8OU5kjLOjE8RDUkz 0VqBeYaZiLf4BJAUO/LfQ87t8heiI29/LyychhxjxwCwde6ZFWe014hl6bziNupBFFop T3DhiN6PTx0zXY32pH+vvV3iNP8Qy4Ptn0y9I=
Hello,
Yes ! It works now !
Many thanks !
As I declared my method "const", I cannot use a non-const iterator.
I just put my iterator in Facet_const_iterator !
-> Facet_const_iterator monIterator=facets_begin();
Gilles
2009/11/20 Laurent Rineau (GeometryFactory) <>
Le jeudi 19 novembre 2009 20:32:34, Gilles a écrit :
> Hello,The only difference I see is that "this", in "void draw() const", is a *const*
> I inheritate from Polyhedron_3 this way :
> typedef CGAL::Simple_cartesian<double> Kernel;
> typedef CGAL::Polyhedron_3<Kernel> Polyhedron_3;
> typedef Polyhedron_3::HalfedgeDS HalfedgeDS;
> typedef HalfedgeDS::Vertex Vertex;
> typedef Vertex::Point Point_3;
> class AC_Nef_Polyhedron : public Polyhedron_3,public AC_Forme3D
> ...and I try to get the facet iterator in a member fonction :
> void AC_Nef_Polyhedron::draw() const
> // it does not work on 'this' ("conversion to non-scalar type
> requested") Facet_iterator monIterator=facets_begin();
> // IT WORKS
> AC_Nef_Polyhedron np (NULL,NULL);
> Facet_iterator t=np.facets_begin();
> // IT ALSO WORKS
> AC_Nef_Polyhedron* hj=new AC_Nef_Polyhedron(NULL,NULL);
> Facet_iterator o=hj->facets_begin();
> Any clue ?
pointer. Is facets_begin() a *const* method?
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] conversion to non-scalar type requested error., Gilles, 11/19/2009
- Re: [cgal-discuss] conversion to non-scalar type requested error., Laurent Rineau (GeometryFactory), 11/20/2009
- Re: [cgal-discuss] conversion to non-scalar type requested error., Gilles Kneuss, 11/20/2009
