- To:
- Subject: Re: [cgal-discuss] 3D Mesh Generation - Multi-domain
- Date: Fri, 20 Nov 2009 10:02:16 +0100
Ramin H wrote:
Thank you for your response. I think I didn't ask my question
properly. I saw *47.3.3 Mesh Generation From a Segmented 3D Image*.
I wanted to know how the multi-domain input can be defined when using
polyhedron domains.
-Ramin
Hi,
There is no such thing in the current implementation.
You will have to define your own multi-domain polyhedron oracle (cf. MeshDomain_3 concept in the reference manual). A naive (and computationnaly costly) solution could be to combine several polyhedron domains, one for each subdomain.
Best,
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
- [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Laurent Rineau (GeometryFactory), 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/17/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Stephane Tayeb, 11/20/2009
- Re: [cgal-discuss] 3D Mesh Generation - Multi-domain, Ramin H, 11/26/2009
