- To:
- Subject: Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3
- Date: Fri, 20 Nov 2009 08:04:13 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=gTRIdij0BnG+sVBD7DTZSQdKRD77Ny7hZrrI9dUYq3xDqgHKLrRVXoRdY3VDhzHyi0 Wzd7G/6WkaRZLhkC3EbBaqCF0CeJrTGu/XTi4DvjchMjGzf1ehEWOURJcPENqKc8Z4On z3DDcU9RB9QwDpa36PjOKNMVUCFb6MLC64Bns=
Thank you for responding. It's ok if the boundary is approximated but
it looks like the algorithm does not finish it's job. I run the Mesh_3
example with no changes to size and approximation factors.
I am attaching the screen shot of the out.mesh, visualized by medit.
Also, here is the .off file that defines the cube:
========= Begin of OFF file ========
OFF
8 6 0
1.632993 0.000000 1.154701
0.000000 1.632993 1.154701
-1.632993 0.000000 1.154701
0.000000 -1.632993 1.154701
1.632993 0.000000 -1.154701
0.000000 1.632993 -1.154701
-1.632993 0.000000 -1.154701
0.000000 -1.632993 -1.154701
4 0 1 2 3
4 7 4 0 3
4 4 5 1 0
4 5 6 2 1
4 3 2 6 7
4 6 5 4 7
========= End of OFF file ========
Thanks,
-Ramin
On Fri, Nov 20, 2009 at 3:49 AM, Stephane Tayeb
wrote:
> Hi,
> Ramin H wrote:
>> Hi everyone,
>> Before I use the 3D mesh generation functionality of CGAL 3.5 over a
>> complicated domain, I decided to use a cube as input to Mesh_3
>> example. The mesh created in out.mesh is missing parts of the surface
>> boundary of the cube.
> What do you mean by missing parts please ?
>> Is it possible to mesh cubes with the 3D mesh generation functionality
>> or they fall under "domains with sharp edges" category?
> Yes it is a domain with sharp edges if you want the have the edges in the
> mesh. The actual implementation is designed for smooth surfaces only.
> If you try to mesh a cube, you will only have an approximation of the edges
> (the element size near the edges depends of the surface approximation error
> criterion).
>> Any idea how one can possibly overcome this issue?
>> Thank you,
>> -Ramin
> Best,
> Stephane Tayeb
> Software engineer - INRIA Sophia Antipolis
> Geometrica Project-Team
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Description: PNG image
- [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3, Ramin H, 11/18/2009
- Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3, Stephane Tayeb, 11/20/2009
- Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3, Ramin H, 11/20/2009
