cgal-discuss - Re: [cgal-discuss] Poisson Reconstruction - Taucs + Pmap
  • To:
  • Subject: Re: [cgal-discuss] Poisson Reconstruction - Taucs + Pmap
  • Date: Mon, 23 Nov 2009 11:29:21 +0100
  • Organization: INFOTERRA
Hi Michael,
Michael Jeulin-L wrote:
Hi,
Excuse me to disturb you one more time, but I have some questions/problems
about/with this package.
First, I saw in the documentation that poisson_reconstruction_function use
TAUCS sparse linear solver and I believe that Taucs was included into CGAL
package (3.5). But, when I try to include the file needed for the computation I
have the following error :
 taucs.h : NO such File or directory (from Taucs_fix.h)
So I don`t know if I have to download and install taucs library separately (I
saw that there also is some problem to do it with gc++) or if I just missed
something else ?
On Windows, CGAL installer should install TAUCS if you select the option (off by default).
Unfortunately, this feature is broken is CGAL 3.5 Windows installer.
Until a fix is available, you may download TAUCS precompiled for Visual C++ from
https://gforge.inria.fr/frs/?group_id=52 (download precompiled_taucs_win32.zip or precompiled_taucs_win64.zip in TAUCS 3.5 section).
On other platforms, you must install TAUCS yourself.
You may download TAUCS from https://gforge.inria.fr/frs/?group_id=52 (download taucs_full.tgz in TAUCS 3.5 section).
Then, see read-me to compile it.
The second question concern Point_with_normal_3 + Pmap [boost], I didn`t find
any documentation to use it with CGAL. For the moment I have
typedef std::pair<Point, Vector> PointVectorPair; from the processus to provide
a points set with normals and I don`t really understand how to use it with the
poisson_reconstruction_function.
Thank you very much.
Regards.
The documentation is available at http://www.cgal.org/Manual/last/doc_html/cgal_manual/Property_map/Chapter_main.html
See more specifically paragraph "71.2.2   Example with Pairs".
Best regards,
Laurent Saboret
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il
contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur
destinataire. Si une erreur de transmission ou une adresse erronée a mal
dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une
réponse par courrier électronique dès réception. Si vous n’êtes pas le
destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en
faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à
une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait
engager de quelque manière que ce soit INFOTERRA France SAS, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely
for the use of the addressee. If you have received this e-mail in error
please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email.
If you are not the addressee of this email, you must not use, keep,
disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind INFOTERRA France SAS in
any contract or obligation, nor its subsidiaries.
