- To:
- Subject: Re: Re: [cgal-discuss] Poisson Reconstruction - Taucs + Pmap
- Date: Mon, 30 Nov 2009 14:30:35 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=orKodzfHngEWfEWe6eM4pSJAZMKcS0TN6z9CvoNK4ey1yKA2EsgRPbqzsv0LDtygo0 Le5YHyz4G0Gp8BHM1/tgGpN9aX/X4n4zgLcijREDh9xMvwTbSbT64EX1n6GrMIvQQg/n DnApU07j4P/paJtZeNDvHe6gdgTA437wC3I6g=
I have successfully compiled Poisson reconstruction with mingw.
2009/11/27 Michael Jeulin-L <>
Hi,
Thank you very much for your answers you avoid me a lot of troubles and useless
efforts.
So, I try to reinstall all I need for my project since your last message...
But now, when I try to compile I have a problem with the GMP library.
Extern Unresolved with _imp__gmpq_sub, imp_gmpq_clear, imp__gmpq_sub, init ...
The thing that I don`t understand is that I compile the library and all seems
to be nice during the compilation.
And when I try to compil with :
gmp-vc90-mt.lib
It doesn`t change anything.
Plus, when I try to compile the solution in CGAL-3.5 I have more than 4K errors
still related to GMP problems.
Did I miss something ?
Thank you very much.
杨成林
Yang Chenglin
- [cgal-discuss] Poisson Reconstruction - Taucs + Pmap, Michael Jeulin-L, 11/23/2009
- Re: [cgal-discuss] Poisson Reconstruction - Taucs + Pmap, Laurent Saboret, 11/23/2009
- Re: Re: [cgal-discuss] Poisson Reconstruction - Taucs + Pmap, Michael Jeulin-L, 11/23/2009
- Re: Re: [cgal-discuss] Poisson Reconstruction - Taucs + Pmap, Michael Jeulin-L, 11/24/2009
- Re: [cgal-discuss] Poisson Reconstruction - Taucs + Pmap, Laurent Saboret, 11/24/2009
- Re: Re: [cgal-discuss] Poisson Reconstruction - Taucs + Pmap, Michael Jeulin-L, 11/27/2009
- Re: Re: [cgal-discuss] Poisson Reconstruction - Taucs + Pmap, 杨成林, 11/30/2009
