- To:
- Subject: Re: [cgal-discuss] can not find liblapack.lib
- Date: Wed, 2 Dec 2009 09:30:41 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=content-type:mime-version:subject:from:in-reply-to:date :content-transfer-encoding:message-id:references:to:x-mailer; b=fxD6rW0izvDV/HZm0P5SDiFypj6xWgCBq41dEQrmq6ENdFFtdaxiCxRXtXvGdW4oio XlfgpwJAyszpsfvbQkmUd6Ic1GCL11+7XjKyk8WJqBILuNBBlr+DNKxt1PdXfwh6CmPa RakzkTvljyHlAqgUkAjFKfsgiFOIVSJNL9uQs=
Some days ago I also had some problems with the taucs installation.
Did you install lapack (or atlas) and did you specify the lib path in cmake?
I'm using Mac OS X and luckily already installed.
regards
Yuri
Am 02.12.2009 um 01:38 schrieb
> Hi guys,
> I am running one of the cgal example and I am getting this error :
> fatal error LNK1104: cannot open file 'liblapack.lib'
> I looked for the liblapack.lib in "C:\CGAL\CGAL-3.5\auxiliary\taucs\lib"
> directory but I couldn't find it. do you have any suggestion to fix it. I
> appreciate your help.
> Thanks,
> Sara
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] can not find liblapack.lib, sara_shafaei, 12/02/2009
- Re: [cgal-discuss] can not find liblapack.lib, Yuri, 12/02/2009
- Re: [cgal-discuss] can not find liblapack.lib, Laurent Saboret, 12/02/2009
- [cgal-discuss] linker error (unresolved external symbol), sara shafaei, 12/02/2009
- Re: [cgal-discuss] linker error (unresolved external symbol), Laurent Saboret, 12/03/2009
