- To:
- Subject: [cgal-discuss] Polyhedron file loading problem
- Date: Wed, 02 Dec 2009 20:42:01 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject :x-enigmail-version:openpgp:content-type; b=L3k+p3K25yTxgmHn4n9LOIqf3zZ6d//wwRNOXxkoawjRscE+FGEfrpVZhghDsAnhvX 988ZPhyCD6oMD0uSUW6VyBSofoMhihb/tALr30bpFhaGnu8+tu/DcljBSGyb/K4juOdK imJUGzIPYl5hwIeK/KYyhrSzIZhxTXF7U9U+Q=
- Openpgp: url=
Hello,
I just downloaded and compiled a fresh copy of CGAL-3.5 and am running
into the following issue. When I run any demo which is supposed to load
a polyhedron_3, CGAL complains that it cannot load the file. For
example, if I try to open a mesh (any .off file from the data directory
that comes with the demos) in the Polyhedron demo, I get a message box
which says "File <file here> has not a known file format". If I click
ok, the message box goes away, but the polyhedron is not created. Any
ideas what might be causing this? CGAL and the demos compile without error.
Cheers,
Rob
signature.asc
Description: OpenPGP digital signature
- [cgal-discuss] Polyhedron file loading problem, Rob, 12/03/2009
- Re: [cgal-discuss] Polyhedron file loading problem, Stephane Tayeb, 12/03/2009
- Re: [cgal-discuss] Polyhedron file loading problem, Rob, 12/03/2009
