cgal-discuss - Re: [cgal-discuss] Polyhedron file loading problem
  • To:
  • Subject: Re: [cgal-discuss] Polyhedron file loading problem
  • Date: Thu, 03 Dec 2009 09:01:58 +0100
Rob wrote:
Hello,
I just downloaded and compiled a fresh copy of CGAL-3.5 and am running
into the following issue. When I run any demo which is supposed to load
a polyhedron_3, CGAL complains that it cannot load the file. For
example, if I try to open a mesh (any .off file from the data directory
that comes with the demos) in the Polyhedron demo, I get a message box
which says "File <file here> has not a known file format". If I click
ok, the message box goes away, but the polyhedron is not created. Any
ideas what might be causing this? CGAL and the demos compile without error.
Cheers,
Rob
Hi,
The polyhedron demo uses several Qt4 plugins (one of them is used to read off files, liboff_plugin.so). Could you confirm that those plugins are loaded at Polyhedron demo start please ?
If I remember well, cmake could put the compiled plugins (dynamic libraries) either in the Polyhedron demo directory or in CGAL-3.5/lib directory.
Best,
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
