cgal-discuss - Re: [cgal-discuss] A geometry question
  • To: <>
  • Subject: Re: [cgal-discuss] A geometry question
  • Date: Thu, 3 Dec 2009 09:09:26 +0100
Atul Thakur wrote:
A polyhedron (non-convex with triangles as its bounding facets) is
given. For a given facet determine the maximum sized sphere that is
tangential to the facet and contained completely inside the
polyhedron.
[snip]
3. Solve following optimization problem:
Maximize R
S.T.
nR^2 - Sum[(x_j - P_center) dot(x_j - P_center) ] >= 0 (as all points
x_j lying on the polyhedron surface lie outside or on the sphere)
0<alpha, beta, gamma<1
R>0
This optimization problem is no good. A sphere can be penetrating a facet even if it does not has any of the points inside. And by summing up constraints, you will have them satisfied only "on average" but not individually.
Best,
Bernd.
