- To:
- Subject: [cgal-discuss] surface meshes from depth maps
- Date: Tue, 8 Dec 2009 12:44:15 +0100
Hello cgal experts,
I am using the surface mesh reconstruction for point sets methods and example
code from
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html
My goal is to convert a depth-map image to a smoothed surface mesh.
I believe my problem is a bit different than the examples provided in the
manual. I have data only from a few viewpoints which are sparsely spread over
an arc of about 30 degrees. Although the datapoints from different
perspectives match quite well to each other, I don't have any data from the
back of the scene for instance.
So far the CGAL functions gave me closed surface meshes, where the back of
the scene was simply reconstructed as a partial sphere.
Is there a way to force the Poisson_reconstruction_function() or
make_surface_mesh() to generate surface sheets instead of closed objects?
Best regards,
Engin Kurutepe.
Engin Kurutepe TU Berlin
FG Nachrichtenübertragung
Tel: +49 30 314 28507 Sekr. EN-1, Einsteinufer 17
Fax: +49 30 314 22514 10587 Berlin Germany
- [cgal-discuss] surface meshes from depth maps, Engin Kurutepe, 12/08/2009
- Re: [cgal-discuss] surface meshes from depth maps, Laurent Saboret, 12/08/2009
- [cgal-discuss] Integrating working installation in Xcode, Nikolas Engelhard, 12/08/2009
- Re: [cgal-discuss] surface meshes from depth maps, 杨成林, 12/09/2009
