- To:
- Subject: Re: [cgal-discuss] how to Check is point inside convex hull 3d?
- Date: Tue, 08 Dec 2009 15:36:16 +0100
Hi Mahdavi,
In case you have many query points, you better construct a 3D Delaunay
triangulation
from the convex hull points and call the locate method for each query point.
andreas
Bernd Gaertner wrote:
mahdavi wrote:
hi all,
I want Check whether point is inside convex hull3d or out convexhull3d or
on convexhull3d? my code for obtain convexhull is:
Polyhedron_3 Poly;
CGAL::Object ch_object;
CGAL::convex_hull_3(Pointch.begin(), Pointch.end(),ch_object );
CGAL::assign(Poly, ch_object);
thanks,
You don't need the convex hull for that. The test can be done with just the points, using linear programming. The CGAL Linear and Quadratic Programming Solver manual has an example program doing exactly this, see http://www.cgal.org/Manual/last/doc_html/cgal_manual/QP_solver/Chapter_main.html#sec:QP-iterators.
Best,
Bernd.
- [cgal-discuss] how to Check is point inside convex hull 3d?, mahdavi, 12/07/2009
- [cgal-discuss] genearting a mesh from cloud points, sara shafaei, 12/07/2009
- Re: [cgal-discuss] genearting a mesh from cloud points, ny, 12/08/2009
- Re: [cgal-discuss] genearting a mesh from cloud points, sara shafaei, 12/08/2009
- Re: [cgal-discuss] how to Check is point inside convex hull 3d?, Bernd Gaertner, 12/08/2009
- Re: [cgal-discuss] how to Check is point inside convex hull 3d?, Andreas Fabri, 12/08/2009
