- To:
- Subject: Re: [cgal-discuss] Re: linking cgal with amira
- Date: Tue, 08 Dec 2009 17:30:30 +0100
Hi Nikos,
what classes do you use in Amira? Do you have a developer version of Amira, such that you have an API and can write/extend your own Amira Modules in C++ or only a "user" Amira (load, display and process data).
What modules/classes do you use - please write more about your project - without specific information it's hard to answer.
Cheers, Cornelia
ny schrieb:
Thanks for your answer Cornelia,
I would like to have additional information
on how to cast the cgal classes into the
amira classes. It sounds good that it is possible,
but it is not straight-forward.
Any hints much appreciated
Cheers!
N
2009/12/8 Cornelia Auer
Hi Nikos,
cgal is not yet incorporated in Amira, we are working on it, but only
internally with a developer licence.
If you have a developer version of Amira, of course you can download cgal
and work with it, but in the end you will always have to cast your cgal
classes to the existing Amira classes and vice versa to combine the power of
the two. But of course it is possible.
Note, that if you use cgal for free, you have to publish your results (see
the licence terms http://www.cgal.org/license.html)
Hope that helped you a bit; if you have further questions don't hesitate...
Cheers,
Cornelia Auer
ny schrieb:
Hi,--
does this mean that there are no cgal users
using the amira software? or it takes some
time to reply
cheers!
\\v//
(o o)
--ooO-(_)-Ooo-----------------
-------- Nikos Yiotis
2009/12/4 ny
Hi all,
I am trying to extend Pierre Alliez's code for estimating
3D normals on 3D meshes via a tensorial PCA-Voronoi
technique as described here::
(*Voronoi-based Variational Reconstruction of Unoriented Point Sets<
http://www.geometry.caltech.edu/pubs/ACTD07.pdf>
*Pierre Alliez, David Cohen-Steiner, Yiying Tong, and Mathieu Desbrun.*
Symposium on Geometry Processing, 2007, pages 39-48)
to the 4D case.
Once this is done I would like to link cgal with amira
visualization software here: http://www.amiravis.com/
I wonder if there are any cgal users experienced with amira.
Indeed the combination of both software will be powerful.
Cheers
N
\\v//
(o o)
PhD candidate, Image Analysis & Computer Graphics Group,
DTU Informatics & Mathematical Modelling, Copenhagen, DK
skype: nyiotis
http://www.linkedin.com/in/yiotis
- [cgal-discuss] linking cgal with amira, ny, 12/04/2009
- [cgal-discuss] Re: linking cgal with amira, ny, 12/08/2009
- Re: [cgal-discuss] Re: linking cgal with amira, Cornelia Auer, 12/08/2009
- Re: [cgal-discuss] Re: linking cgal with amira, ny, 12/08/2009
