cgal-discuss - Re: [cgal-discuss] Compiling under Windows using mingw.
  • To:
  • Subject: Re: [cgal-discuss] Compiling under Windows using mingw.
  • Date: Thu, 10 Dec 2009 09:52:22 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=xwrzPOpxky63hBX2tFFgLmZSxuZizldtMnJOIvQQTX9IDujJ0CMAfY/uREtmxqouQV 6vUkDSxqqMyH28MxrKJdz6TFN18qI9S8deZoGHrf2pU7NJhHZlOV0EbMQHrhJQdwCKUU d00qAQJoWaz7Amjf+HBYCsszqBUMy1vDqoWzs=
CGAL can be compiled with mingw. It is easy.
2009/12/10 Gilles <>
Hello all,
I'm now under developpement and I hope that, one of these days, I will have to
compile the project under Windows.
-> Have I correctly understood : there is no way to make it with mingw compiler
-> If not, is there anybody doing this (I mean compiling cgal under Windows
with mingw). It seems that, unless using Microsoft (Visual) compiler, it's a
bit complicated !
Thanks for reply !
Gilles
PS : I'am using now QCreator, with GCC under Linux, it works very fine...
杨成林
Yang Chenglin
