cgal-discuss - Re: [cgal-discuss] Compiling under Windows using mingw.
  • To:
  • Subject: Re: [cgal-discuss] Compiling under Windows using mingw.
  • Date: Fri, 11 Dec 2009 09:17:03 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=xDEIB6mnKa60XdUU3Uptz3uuJn2v0mDp/QhAjO1AGpWe9txQa8SCXo6MuSgMy/LoWt LW0UJkRKNOzQn7eKO1wkr3QaTxhxZ+LbpDzD7/twLcefbGGKfHoAFsl3Bb2HT5LXVp7M 4XQHUbVVD0gLWcIkgxYZvqNDmVcqjFCyMQqdk=
Just follow the installation manual of CGAL. First build the required libs, then use Cmake, just as what you do under linux.
2009/12/10 Gilles Kneuss <>
Hello Yang,
Thank you for reply.
-> Would you please tell me a bit more : Were can I find information about how to do it simply !
Thank you in advance.
Gilles
2009/12/10 杨成林 <>
CGAL can be compiled with mingw. It is easy.
2009/12/10 Gilles <>
Hello all,
I'm now under developpement and I hope that, one of these days, I will have to
compile the project under Windows.
-> Have I correctly understood : there is no way to make it with mingw compiler
-> If not, is there anybody doing this (I mean compiling cgal under Windows
with mingw). It seems that, unless using Microsoft (Visual) compiler, it's a
bit complicated !
Thanks for reply !
Gilles
PS : I'am using now QCreator, with GCC under Linux, it works very fine...
杨成林
Yang Chenglin
杨成林
Yang Chenglin
