- To:
- Subject: Re: [cgal-discuss] Compiling under Windows using mingw.
- Date: Thu, 10 Dec 2009 16:05:19 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=DLBihOHSl5Ws/fLKP4bW4lxR0jRh9Q86u/f/0Rk4GXVfMpQ3PwKUG2huMiv0eMJ5T0 xA/k4UH8JKYExxrL1B4ea1M8/mM67i3P8NzI0VYoj1Hj9VQ3t8hAFBp50cNl5RMzsVu1 ISGfWjvrD3IzKbueoCx+Q+nU567ej0OzpZBpI=
Hello Yang,
Thank you for reply.
-> Would you please tell me a bit more : Were can I find information about how to do it simply !
Thank you in advance.
Gilles
2009/12/10 杨成林 <>
CGAL can be compiled with mingw. It is easy.
2009/12/10 Gilles <>
Hello all,
I'm now under developpement and I hope that, one of these days, I will have to
compile the project under Windows.
-> Have I correctly understood : there is no way to make it with mingw compiler
-> If not, is there anybody doing this (I mean compiling cgal under Windows
with mingw). It seems that, unless using Microsoft (Visual) compiler, it's a
bit complicated !
Thanks for reply !
Gilles
PS : I'am using now QCreator, with GCC under Linux, it works very fine...
杨成林
Yang Chenglin
- [cgal-discuss] Compiling under Windows using mingw., Gilles, 12/09/2009
- Re: [cgal-discuss] Compiling under Windows using mingw., 杨成林, 12/10/2009
- Re: [cgal-discuss] Compiling under Windows using mingw., Gilles Kneuss, 12/10/2009
- Re: [cgal-discuss] Compiling under Windows using mingw., 杨成林, 12/11/2009
