[cgal-discuss] which operation is more efficient when proccsing with large size Delaunay_triangulation_3
- To:
- Subject: [cgal-discuss] which operation is more efficient when proccsing with large size Delaunay_triangulation_3
- Date: Fri, 11 Dec 2009 13:41:53 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=ReEU0AwO6V157jXotIdsiLPK6VUnhfX+BT21FySeWIBxwkLU3/29x7ky5nujoCf7xr 0hPu+4wPydbtRJg6rULQX7v1mwXcOsKnPrlKBSYagwcQDtV6dF+4YG7wFfhBhR7fsbF4 uPDs4xt7+Y4oAEWpfvzBxo5pfwXbB9WDo+wl4=
Hi, all
Currently, I'm doing some isotropic remeshing jobs. I try to remesh a Delaunay triangluation_3 which has 1~5 million vertices.
At the end of each optimization step, the location of the vertices will be update to another place. and as i know, there are two method to finish this update:
1) using one triangulation object and use the "Triangluation_3::move_point()" operation;
2) using two copy triangulation objects. and use the "t.swap ( Triangulation_3 & tr)" operation to update the whole triangulation.
Is there any one know the efficient between these two operations, which one is more fast?
Best regards
shuchu
- [cgal-discuss] which operation is more efficient when proccsing with large size Delaunay_triangulation_3, Shuchu Han, 12/11/2009
- Re: [cgal-discuss] which operation is more efficient when proccsing with large size Delaunay_triangulation_3, Pedro Machado Manhães de Castro, 12/11/2009
- Re: [cgal-discuss] which operation is more efficient when proccsing with large size Delaunay_triangulation_3, Daniel Duque, 12/11/2009
- Re: [cgal-discuss] which operation is more efficient when proccsing with large size Delaunay_triangulation_3, Shuchu Han, 12/17/2009
