cgal-discuss - Re: [cgal-discuss] which operation is more efficient when proccsing with large size Delaunay_triangulation_3
  • To:
  • Subject: Re: [cgal-discuss] which operation is more efficient when proccsing with large size Delaunay_triangulation_3
  • Date: Fri, 11 Dec 2009 13:31:51 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=t0AqyX89J9Q+YTMn54EmMjDLpOdDptDFB01vuFoYd1nGBIVwLr4O7Cmkx923vfbZpT R1FpGbB4rXk2XzuqdfyARMsEIFUy9eW64v5ZcHR5UoU75hUykEuZVCCRkW3lBWG1XMXA J0h5hZ104Sz6LAbYKqenmVCXuQtGJDw8Ptvko=
Hello,
As far as I understood, you are within a static setting since you know the next position of all the points, and all your points move.
Then, in general, your approach (2) is better (rebuilding). Allow me to show you a better way to do that.
Instead of maintaining 1 original and 1 copy of such a huge triangulation, and swapping them, you can do as follow:
Have a container (list, vector) with all the new positions (several Point_3) and simply do
tr.clear();
tr.insert(points.begin(), points.end());
Depending on your application there are two methods that have shown some quality in practice (improve on rebuilding for some data-sets) for Delaunay triangulations:
(static setting) Heuristics + Flipping:
Leonidas Guibas and Daniel Russel
An empirical comparison of techniques for updating Delaunay triangulations.
SCG '04: Proceedings of the twentieth annual symposium on Computational geometry, pages 170-179.
(dynamic setting) Filtering Relocations:
Pedro Machado Manhães de Castro, Jane Tournois, Pierre Alliez, and Olivier Devillers.
Filtering relocations on a Delaunay triangulation. Computer Graphics Forum, 28:1465-1474, 2009. Note: Special issue for EUROGRAPHICS Symposium on Geometry Processing.
Best regards,
Pedro Machado Manhaes de Castro
On Fri, Dec 11, 2009 at 6:41 AM, Shuchu Han <> wrote:
Hi, all
Currently, I'm doing some isotropic remeshing jobs. I try to remesh  a Delaunay triangluation_3 which has 1~5 million vertices.
At the end of each optimization step, the location of the vertices will be update to another place.  and as i know, there are two method to finish this update:
1)  using one triangulation object and use the   "Triangluation_3::move_point()"  operation;
2) using two copy triangulation objects.  and  use the "t.swap ( Triangulation_3 & tr)" operation to update the whole triangulation.
Is there any one know the efficient between these two operations, which one is more fast?
Best regards
shuchu
