cgal-discuss - Re: [cgal-discuss] linker error in cgal example
  • To:
  • Subject: Re: [cgal-discuss] linker error in cgal example
  • Date: Fri, 11 Dec 2009 09:51:02 +0100
  • Organization: INFOTERRA
Hi Tina,
Your problem is probably:
LINK : warning LNK4098: defaultlib 'MSVCRTD' conflicts with use of other libs; use /NODEFAULTLIB:library
which indicates that you are trying to link your application with libraries compiled with a different runtime.
Please recompile your code (the application and any library you might use):
- with "Multi-threaded Debug DLL (/MDd)" for the Debug target and "Multi-threaded DLL (/MD)" for the Release target (as suggested by Pierre)
- without linking explicitly with GMP library in the project properties (CGAL should pick the proper libraries automatically)
- with CGAL_LIB_DIAGNOSTIC (as suggested by Laurent R.)
Note that the 2 first points are the default in CMake-generated VC++ projects.
If it still doesn't work, please post the new compilation log.
Best regards,
Laurent Saboret
tina rumi wrote:
Hi Laurent,
Thanks for the reply. I am using Microsoft Visual Studio 2008 version 9 and windows XP 64 . I am not sure that include service pack. I just installed it from CD.
I recompile it with the CGAL_LIB_DIAGNOSTIC and attached the log to this e-mail.
Thank you,
Tina
On Thu, Dec 10, 2009 at 6:11 PM, Laurent Rineau (GeometryFactory) <> wrote:
Le jeudi 10 décembre 2009 19:00:53, tina rumi a écrit :
> Hi Laurent,
> Thank you for your reply. I tried with the cmake too but still same errors.
> I even addressed all the lib files in my code individually and still have
> same error. I am guessing the problem is not finding library. maybe I am
> missing some of  the lib file.  I have following files :
> "C:\CGAL\CGAL-3.5\auxiliary\gmp\lib" :
> gmp-vc90-mt.lib
> gmp-vc90-mt-gd.lib
> gmp-vc90-mt-s.lib
> gmp-vc90-mt-sgd.lib
> mpfr-vc90-mt.lib
> mpfr-vc90-mt-gd.lib
> mpfr-vc90-mt-s.lib
> mpfr-vc90-mt-sgd.lib
> gmp-vc90-mt.dll
> gmp-vc90-mt-gd.dll
> mpfr-vc90-mt.dll
> mpfr-vc90-mt-gd.dll
> and in "C:\CGAL\CGAL-3.5\auxiliary\gmp\include" :
> gmp.h
> mpfr.h
> Is there any file missing? I really appreciate your help, I don't know what
> else should I do.
There is something strange. We need more information to understand. What
version of the MSVS C++ Compiler do you use? Have you installed MSVS service
packs?
Can you retry to compile the same program with the cpp macro
CGAL_LIB_DIAGNOSTIC defined, and give use the full compilation log (that should
then display the list of auto-linked CGAL libraries).
Same question for Pierre, who also seems to have problems with Visual and GMP.
Laurent Rineau, PhD
Release Manager of the CGAL Project       http://www.cgal.org/
R&D
Engineer at GeometryFactory           http://www.geometryfactory.com/
Build Log
Rebuild started: Project: cloud_points, Configuration: Debug|Win32
Command Lines
Creating temporary file "f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000511723792.rsp" with contents
/Od /I "C:\Program Files (x86)\boost\boost_1_40" /I "C:\CGAL\CGAL-3.5\include" /I "C:\CGAL\CGAL-3.5\auxiliary\gmp\include" /I "C:\Qt\2009.04\qt\include\QtCore" /I "C:\Qt\2009.04\qt\include\QtGui" /I "C:\Qt\2009.04\qt\include" /I "C:\Qt\2009.04\qt\include\ActiveQt" /I "debug" /I "." /I "C:\Qt\2009.04\qt\mkspecs\win32-msvc2005" /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_UNICODE" /D "UNICODE" /D "_AFXDLL" /Gm /EHsc /RTC1 /MD /Yu"stdafx.h" /Fp"Debug\cloud_points.pch" /Fo"Debug\\" /Fd"Debug\vc90.pdb" /W3 /c /ZI /TP .\cloud_points.cpp
Creating command line "cl.exe @f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000511723792.rsp /nologo /errorReport:prompt"
Creating temporary file "f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000611723792.rsp" with contents
/Od /I "C:\Program Files (x86)\boost\boost_1_40" /I "C:\CGAL\CGAL-3.5\include" /I "C:\CGAL\CGAL-3.5\auxiliary\gmp\include" /I "C:\Qt\2009.04\qt\include\QtCore" /I "C:\Qt\2009.04\qt\include\QtGui" /I "C:\Qt\2009.04\qt\include" /I "C:\Qt\2009.04\qt\include\ActiveQt" /I "debug" /I "." /I "C:\Qt\2009.04\qt\mkspecs\win32-msvc2005" /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_UNICODE" /D "UNICODE" /D "_AFXDLL" /Gm /EHsc /RTC1 /MD /Yc"stdafx.h" /Fp"Debug\cloud_points.pch" /Fo"Debug\\" /Fd"Debug\vc90.pdb" /W3 /c /ZI /TP .\stdafx.cpp
Creating command line "cl.exe @f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000611723792.rsp /nologo /errorReport:prompt"
Creating temporary file "f:\fingerprint\codes\cloud_points\cloud_points\Debug\TMP00000711723792.tmp" with contents
1 /* CREATEPROCESS_MANIFEST_RESOURCE_ID */ 24 /* RT_MANIFEST */ ".\\Debug\\cloud_points.exe.embed.manifest"
Creating command line "rc.exe /fo".\Debug\cloud_points.exe.embed.manifest.res" f:\fingerprint\codes\cloud_points\cloud_points\Debug\TMP00000711723792.tmp"
Creating temporary file "f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000811723792.rsp" with contents
/OUT:"F:\fingerprint\codes\cloud_points\Debug\cloud_points.exe" /INCREMENTAL /MANIFEST /MANIFESTFILE:"Debug\cloud_points.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"F:\fingerprint\codes\cloud_points\Debug\cloud_points.pdb" /SUBSYSTEM:CONSOLE /DYNAMICBASE /NXCOMPAT /MACHINE:X86 C:\Qt\2009.04\qt\lib\qtmaind.lib C:\Qt\2009.04\qt\lib\QtGuid4.lib C:\Qt\2009.04\qt\lib\QtCored4.lib psapi.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\gmp-vc90-mt.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\gmp-vc90-mt-gd.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\gmp-vc90-mt-s.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\gmp-vc90-mt-sgd.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\mpfr-vc90-mt.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\mpfr-vc90-mt-gd.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\mpfr-vc90-mt-s.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\mpfr-vc90-mt-sgd.lib
".\Debug\cloud_points.obj"
".\Debug\stdafx.obj"
Creating command line "link.exe @f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000811723792.rsp /NOLOGO /ERRORREPORT:PROMPT"
Output Window
Compiling...
stdafx.cpp
Compiling...
cloud_points.cpp
Linking to lib file: CGAL-vc90-mt-gd.lib
Linking to lib file: gmp-vc90-mt-gd.lib
Linking to lib file: mpfr-vc90-mt-gd.lib
Linking to lib file: libtaucs-vc90-mt-gd.lib
Linking to lib file: libmetis-vc90-mt-gd.lib
Linking to lib file: liblapack.lib
Linking to lib file: libf77blas.lib
Linking to lib file: libcblas.lib
Linking to lib file: libatlas.lib
Linking to lib file: vcf2c-vc90-mt-gd.lib
c:\cgal\cgal-3.5\include\cgal\win32_exception.h(77) : warning C4535: calling _set_se_translator() requires /EHa
c:\cgal\cgal-3.5\include\cgal\taucs_solver.h(227) : warning C4996: 'tempnam': The POSIX name for this item is deprecated. Instead, use the ISO C++ conformant name: _tempnam. See online help for details.
        c:\program files (x86)\microsoft visual studio 9.0\vc\include\stdio.h(713) : see declaration of 'tempnam'
        c:\cgal\cgal-3.5\include\cgal\taucs_solver.h(190) : while compiling class template member function 'bool CGAL::Taucs_solver::factorize_ooc(void)'
        with
            T=double
        c:\cgal\cgal-3.5\include\cgal\poisson_reconstruction_function.h(325) : see reference to class template instantiation 'CGAL::Taucs_solver' being compiled
        with
            T=double
        c:\cgal\cgal-3.5\include\cgal\poisson_reconstruction_function.h(300) : while compiling class template member function 'bool CGAL::Poisson_reconstruction_function::solve_poisson(double)'
        with
            Gt=Kernel
        f:\fingerprint\codes\cloud_points\cloud_points\cloud_points.cpp(209) : see reference to class template instantiation 'CGAL::Poisson_reconstruction_function' being compiled
        with
            Gt=Kernel
c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(119) : warning C4996: 'std::copy': Function call with parameters that may be unsafe - this call relies on the caller to check that the passed values are correct. To disable this warning, use -D_SCL_SECURE_NO_WARNINGS. See documentation on how to use Visual C++ 'Checked Iterators'
        c:\program files (x86)\microsoft visual studio 9.0\vc\include\xutility(2550) : see declaration of 'std::copy'
        c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(115) : while compiling class template member function 'CGAL::Kd_tree_rectangle::Kd_tree_rectangle(const CGAL::Kd_tree_rectangle &)'
        with
            SearchTraits=Tree_traits
        c:\cgal\cgal-3.5\include\cgal\kd_tree.h(254) : see reference to class template instantiation 'CGAL::Kd_tree_rectangle' being compiled
        with
        c:\cgal\cgal-3.5\include\cgal\kd_tree.h(252) : while compiling class template member function 'CGAL::Kd_tree::~Kd_tree(void)'
        with
            SearchTraits=Tree_traits,
            Splitter_=CGAL::Sliding_midpoint,
            UseExtendedNode=CGAL::Tag_true
        c:\cgal\cgal-3.5\include\cgal\orthogonal_k_neighbor_search.h(52) : see reference to class template instantiation 'CGAL::Kd_tree' being compiled
        with
        c:\cgal\cgal-3.5\include\cgal\compute_average_spacing.h(129) : see reference to class template instantiation 'CGAL::Orthogonal_k_neighbor_search' being compiled
        with
        c:\cgal\cgal-3.5\include\cgal\compute_average_spacing.h(183) : see reference to function template instantiation 'double CGAL::compute_average_spacing>(InputIterator,InputIterator,PointPMap,unsigned int,const Kernel &)' being compiled
        with
            InputIterator=std::_Vector_iterator>,
            PointPMap=CGAL::Dereference_property_map>,
            CK=CGAL::Simple_cartesian,
            Kernel=CGAL::Filtered_kernel>
        c:\cgal\cgal-3.5\include\cgal\compute_average_spacing.h(199) : see reference to function template instantiation 'double CGAL::compute_average_spacing>(InputIterator,InputIterator,PointPMap,unsigned int)' being compiled
        with
            T=CGAL::Point_with_normal_3,
        f:\fingerprint\codes\cloud_points\cloud_points\cloud_points.cpp(218) : see reference to function template instantiation 'double CGAL::compute_average_spacing<_Ty,_Alloc>>(InputIterator,InputIterator,unsigned int)' being compiled
        with
            _Ty=Point_with_normal,
            _Alloc=std::allocator,
c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(120) : warning C4996: 'std::copy': Function call with parameters that may be unsafe - this call relies on the caller to check that the passed values are correct. To disable this warning, use -D_SCL_SECURE_NO_WARNINGS. See documentation on how to use Visual C++ 'Checked Iterators'
c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d\min_sphere_of_spheres_d_pair.h(112) : warning C4244: '=' : conversion from 'double' to 'float', possible loss of data
        c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d\min_sphere_of_spheres_d_impl.h(178) : see reference to function template instantiation 'T CGAL::inner_product_n<3,float,const double*,const double*,std::plus<_Ty>,CGAL::Min_sphere_of_spheres_d_impl::Subtract_and_square>(InputIterator1,InputIterator2,T,BinaryOperation1,BinaryOperation2)' being compiled
        with
            T=float,
            _Ty=double,
            FT=double,
            InputIterator1=const double *,
            InputIterator2=const double *,
            BinaryOperation1=std::plus,
            BinaryOperation2=CGAL::Min_sphere_of_spheres_d_impl::Subtract_and_square
        c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d\min_sphere_of_spheres_d_impl.h(164) : while compiling class template member function 'bool CGAL::Min_sphere_of_spheres_d::find_farthest(int,int,int &,CGAL::Tag_false,CGAL::Tag_false)'
        with
            Traits=Traits
        c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d.h(183) : while compiling class template member function 'void CGAL::Min_sphere_of_spheres_d::prepare(int)'
        with
            Traits=Traits
        c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d.h(206) : while compiling class template member function 'bool CGAL::Min_sphere_of_spheres_d::is_empty(void)'
        with
            Traits=Traits
        c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d.h(214) : while compiling class template member function 'const double &CGAL::Min_sphere_of_spheres_d::radius(void)'
        with
            Traits=Traits
        c:\cgal\cgal-3.5\include\cgal\reconstruction_triangulation_3.h(348) : see reference to class template instantiation 'CGAL::Min_sphere_of_spheres_d' being compiled
        with
            Traits=Traits
        c:\cgal\cgal-3.5\include\cgal\reconstruction_triangulation_3.h(337) : while compiling class template member function 'CGAL::Sphere_3 CGAL::Reconstruction_triangulation_3::input_points_bounding_sphere(void) const'
        with
            R_=CGAL::Filtered_kernel>,
            BaseGt=CGAL::Robust_circumcenter_filtered_traits_3
        c:\cgal\cgal-3.5\include\cgal\poisson_reconstruction_function.h(82) : see reference to class template instantiation 'CGAL::Reconstruction_triangulation_3' being compiled
        with
c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(245) : warning C4996: 'std::copy': Function call with parameters that may be unsafe - this call relies on the caller to check that the passed values are correct. To disable this warning, use -D_SCL_SECURE_NO_WARNINGS. See documentation on how to use Visual C++ 'Checked Iterators'
        c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(242) : while compiling class template member function 'CGAL::Kd_tree_rectangle &CGAL::Kd_tree_rectangle::operator =(const CGAL::Kd_tree_rectangle &)'
        with
c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(246) : warning C4996: 'std::copy': Function call with parameters that may be unsafe - this call relies on the caller to check that the passed values are correct. To disable this warning, use -D_SCL_SECURE_NO_WARNINGS. See documentation on how to use Visual C++ 'Checked Iterators'
Compiling manifest to resources...
Microsoft (R) Windows (R) Resource Compiler Version 6.0.5724.0
Copyright (C) Microsoft Corporation.  All rights reserved.
Linking...
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_clear referenced in function "public: __thiscall CGAL::Gmpq_rep::~Gmpq_rep(void)public: __thiscall CGAL::Gmpq::Gmpq(double)public: __thiscall CGAL::Gmpq_rep::Gmpq_rep(void)public: class CGAL::Gmpq & __thiscall CGAL::Gmpq::operator*=(class CGAL::Gmpq const &)bool __cdecl CGAL::operator==(class CGAL::Gmpq const &,int)public: struct std::pair __thiscall CGAL::Real_embeddable_traits::To_interval::operator()(class CGAL::Gmpq const &)const public: struct std::pair __thiscall CGAL::Real_embeddable_traits::To_interval::operator()(class CGAL::Gmpq const &)const public: struct std::pair __thiscall CGAL::Real_embeddable_traits::To_interval::operator()(class CGAL::Gmpq const &)const public: struct std::pair __thiscall CGAL::Real_embeddable_traits::To_interval::operator()(class CGAL::Gmpq const &)const public: class CGAL::Gmpq & __thiscall CGAL::Gmpq::operator+=(class CGAL::Gmpq const &)public: class CGAL::Gmpq & __thiscall CGAL::Gmpq::operator-=(class CGAL::Gmpq const &)public: __thiscall CGAL::Gmpq::Gmpq(int)public: class CGAL::Gmpq & __thiscall CGAL::Gmpq::operator/=(class CGAL::Gmpq const &)bool __cdecl CGAL::operator<(class CGAL::Gmpq const &,class CGAL::Gmpq const &)bool __cdecl CGAL::operator==(class CGAL::Gmpq const &,class CGAL::Gmpq const &)" (??8CGAL@@YA_NABVGmpq@0@0@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_set referenced in function ___gmpq_neg
F:\fingerprint\codes\cloud_points\Debug\cloud_points.exe : fatal error LNK1120: 16 unresolved externals
Results
Build log was saved at "file://f:\fingerprint\codes\cloud_points\cloud_points\Debug\BuildLog.htm"
cloud_points - 17 error(s), 8 warning(s)
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il
contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur
destinataire. Si une erreur de transmission ou une adresse erronée a mal
dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une
réponse par courrier électronique dès réception. Si vous n’êtes pas le
destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en
faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à
une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait
engager de quelque manière que ce soit INFOTERRA France SAS, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely
for the use of the addressee. If you have received this e-mail in error
please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email.
If you are not the addressee of this email, you must not use, keep,
disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind INFOTERRA France SAS in
any contract or obligation, nor its subsidiaries.
