- To:
- Subject: Re: [cgal-discuss] run program cgal by vc8
- Date: Fri, 18 Dec 2009 05:12:10 -0800 (PST)
I solved that problem by reinstall the boost and the cgal, I guess the key
point is to choose the right option(variants) when installing at the
beginning. The right for boost is
Multithread Debug, DLL
Multithread,DLL
Multithread
Multithread Debug
Multithread, static runtime
Multithread Debug, static runtime
(not contains last two option)
And the right for cgal is
Multithread Debug
Multithread
It works, but what is weird is the words in the manual page(installation
manual:
http://www.cgal.org/Manual/3.4/doc_html/installation_manual/Chapter_installation_manual.html#Footnote_12
)4.6 Static vs.Dynamic Libraries:Under windows we only support the static
versions of the CGAL libraries...
So I guess the cgal can work with either static, or dynamic libs, but never
both.
View this message in context:
http://n4.nabble.com/run-program-cgal-by-vc8-tp953343p974757.html
- Re: [cgal-discuss] run program cgal by vc8, variable, 12/17/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] run program cgal by vc8, variable, 12/18/2009
- Re: [cgal-discuss] run program cgal by vc8, Laurent Rineau (GeometryFactory), 12/18/2009
- Re: [cgal-discuss] run program cgal by vc8, variable, 12/21/2009
